ANC
ANC
JNev
MRY Monterey Tower
This probably isn't the appropriate place to ask, but what is exactly is a temporary bid?
Maintainvfr
It's exactly what it sounds like, usually a 3 or 5 year assignment. It would typically end in returning to your previous facility or getting a list of other facilities.
axman
Disregard his post. In this instance a temp bid (critical staffing) as it says is immediate staffing. Alaska gets slammed in the summer. There are 3 facilities that have a temp bid (180 days) to get through the summer.
JNev
MRY Monterey Tower
How do you help when you can’t even checkout our at the easiest facilities in 180 days?
axman
Usually it’ll be people that have been certified there before- someone who should be able to certify in a month.
randoturbo33
For those that are interested.
This may be a dumb question, but why would anyone do this? Do they offer housing and/or per diem? If I'm reading it correctly, your pay stays exactly the same, the FAA doesn't pay relocation expenses, and the job can be terminated early at their discretion. So you'd have to find some sort of a lease or extended stay situation and pay for that in addition to your already-existing expenses at home?
  • Like
Reactions: ZP
Because summer in Alaska is awesome.
DL0509
This is just a guess but since it's a TDY assignment I'm pretty sure the contract covers you not having to pay for housing. That's just a guess though, and as stated above I'd do it just because it's summer in Alaska.
mrobs15
And pay staying the same sounds pretty sweet to a level 9+ controller thinking about going.
DL0509
The bid specifically says that those selected must have a gov card. Does that mean if they give you one for this bid you will miss out on the per diem?
Stinger
Moderator
No...per diem is given regardless of whether you have a travel card or not.
FoggyWindow
ZHU Houston Center
I'm putting in for this one, Juneau, and Fairbranks. I'd love to spend a summer in AK. Is the position for working tower only or do you get to work radar too?
Foogy
That's like 60k per diem isn't it for ANC, 55k for AJN for 180 days... I'm buying a nice tent and sleeping bag for this trip.
FoggyWindow
ZHU Houston Center
No, per diem will be a little under $3k per month.
A11 is a separate facility. FAI is an up down. JNU is tower only
Any idea if I'd be working radars too as FAI? I suspect its just to work the tower but I've got CTO's and radars so was hoping I could do both, assuming I got an offer.
Alpha_bravo2
PNS Pensacola Tower
So I was looking into per diem and I noticed that the rates for ANC we're north of 300 a day, can anyone confirm?
