CPC Transfer Pay Question
breakaway2000
Quick question for anyone that can answer it. Per the Slate book for CPC transfers...
(1) One-half (1/2) of the increase is paid upon initial transfer to
the new facility; the other one-half (1/2) is paid when fully
certified in the new facility.
Is this a straight dollar amount raise ala you get to 'keep' each raise in Jan/Aug? EX. To keep the math simple. Lets say you go from $85,000 to $115,000, $30,000 difference. $15,000 on the go has you starting at $100,000, 1.6% raise in August bumps you up to $101,600. You certify in December, does your pay go to the band minimum (115k) or does it simply add $15,000 on to your current salary to give you $116,600?
X-Ray Lima
Puppy Monkey Baby!
Let's say you washout as a CPC-IT, same scenario above. Do you keep your raise amounts off your CPC-IT pay and they add them back to your previous CPC pay or do they recalculate your raises based off of your last CPC pay? 3-6 pay raises based off of 100k vs 85k is huge!
Dontbotherme
The contract says your pay is set as if you never left your prior facility. You'd get the pay raises on top of that amount prior CPC pay.
X-Ray Lima
Puppy Monkey Baby!
What if your a developmental and make it to D3 and go to NEST where does your pay fall then? AG at your new facility or wherever D3 falls in the payband at your new facility?
ATC_av8er
CPC, Level 6, 22.93% locality. LES says I make $82,194. Want to transfer Level 7, rest of US locality. I can't seem to figure out the math right now. Can anyone help me figure out what my raise will be, if any? Thanks in advance.
[greater of Basic pay x 1.06 or bottom of lvl7 cpc] x new locality
rugbydog11
82194 / 1.2293 = 66862 as your basic (no locality)
6% increase would be greater than bottom 70,874 vs 69,520 (jan 17 pay scale)
70,874 x 1.1506 (RofUS) = 81,547
I'm bored enough to do math homework...
Andrew
lol well if you are bored what will it be going from a level 8 to 9?? Standard locality
