Since this list is getting updated weekly, can you also update as often? Also, average terminal and enroute pass rates at the academy are about 3-5 people per class of eighteen. The highest was 11 of 18 a few months ago. Instructors, problems, and evaluators make up all the variables.
At the beginning of April, the En Route Placement List was transitioned from an Excel-based list to a web-based databasing program (SharePoint, maybe?), therefore I would assume it's fairly unlikely the list will get updated again on this website. They're also refreshing the list weekly rather than monthly at this point. Facilities that I didn't see on the list during the month of April: Boston, Jacksonville, Salt Lake, Denver, Seattle, Albuquerque, Atlanta, Fort Worth, Memphis, and Cleveland. I didn't see every single class's list, so it may be slightly inaccurate.
As for the pass rate, your average is way out of whack. I was there December through April; the last seven en route classes passed 47 of 107 (44%). As for those who are failing, I think HenryTheAce is a a bit off base as well. There are certainly those that blame everyone else, but the majority I've known recognize that the pressure made them crack and make mistakes. Most people that fail know how to do everything that's seen in evaluations, it's just performing under the microscope. The volume of learning that's required in radar is immense as well. That's not even mentioning adding the emotional aspect of seeing classmates who are like family at this point washout before you go into a run and just how simple it is for lost points to pile up in an evaluation. One big mistake can literally cost you half of your available points. Even small mistakes add up quick. It's difficult. It takes confidence in yourself, grit, non-stop studying, quality instructors, sprinkled in with some luck to pass the program.
Terminal wise, the last figures going around were something like 5 of the last 35 to eval had passed. Again, take that grain of salt since I have nothing to do with terminal.
