Air Traffic Control Specialist - Trainee
Overview
Many vacancies in the following location:
Relocation expenses reimbursed
No
Telework eligible
No
This job is open to
Apply
Announcement number
FAA-ATO-18-ALLN90 -54212
Control number
502735700
Duties
Summary
Air Traffic Control Specialists in the Terminal Approach Control provides radar services to aircraft arriving and departing airports and transiting Terminal airspace. They transfer control of aircraft to the ARTCC controller when the aircraft leaves assigned airspace and they receive control of aircraft coming into assigned airspace.
Responsibilities
Duty location for these positions is N90/NEW YORK TRACON LOCATED IN WESTBURY, NY. You must reside within the area of consideration (AOC) defined as within a 50 mile radius of Westbury, NY.
This is a developmental Air Traffic Control Specialist (ATCS) position responsible for the safe, orderly and expeditious movement of air traffic through the New York Terminal Radar Approach Control (TRACON) airspace.
As a new ATCS, you will spend your first several weeks of employment in an intensive training program at the FAA Academy in Oklahoma City, OK. While attending training you will be on a temporary appointment. Applicants selected will receive air traffic control training at the FAA Academy, which includes:
Individuals who do not successfully complete training at the FAA Academy and all other necessary requirements will have their employment terminated.
Prior failure of FAA Academy training or prior declination of permanent facility placement offer after completing Academy training may constitute a basis for non-selection and/or veterans' preference pass over.
Upon successful completion of the Academy initial training program & other employment requirements, newly hired ATCS's will be offered a permanent appointment at an FAA facility with a basic salary of $39,115, plus applicable locality pay based on facility assignment. Applicants with prior ATC experience will have their salary set in accordance with the ATCS Collective Bargaining Agreement, upon conversion.
ATCS's will be paid long term expense rate (per diem) for Oklahoma City, OK to help offset daily cost of living while attending FAA Academy. FAA will pay for cost of travel in accordance with applicable agency policies.
As an ATCS you will receive pay increases as you successfully complete the progressive phases of controller training at your assigned facility. The FAA has Air Traffic Control Facilities in every state as well as Puerto Rico, The U. S. Virgin Islands, and Guam. This announcement is only open to those applicants willing to work at N90, New York TRACON located in Westbury New York and who reside within the area of consideration (AOC) defined as within a 50 mile radius of Westbury, NY.
Prior experience or training in air traffic control is not required. If a candidate applies for and is selected under this temporary trainee announcement, all of the employment conditions associated with this FG-1 position will apply, regardless of whether the candidate possesses the specialized experience that would have otherwise qualified him/her under the March 2018 vacancy announcement FAA-ATO-ATCEXP-56707.
Travel Required
Occasional travel - The job may require travel from time- to-time, but not on a regular basis. The travel may be for training or other work-related duties.
Supervisory status
No
Promotion Potential
1
Job family (Series)
2152 Air Traffic Control
Similar jobs
Requirements
Conditions of Employment
Qualifications
You may qualify in 1 of the following 5 ways:
Successful candidates must be able to speak English clearly enough to be understood over radios, intercoms, and similar communications equipment.
Veterans Recruitment Appointment (VRA) eligible applicants:
Veterans claiming eligibility on the basis of service in a campaign or expedition for which a medal was awarded must be in receipt of the campaign badge or medal.
In addition to meeting the criteria above, eligible veterans must have been separated under honorable conditions (i.e., the individual must have received either an honorable or general discharge). Please also see the section 'All Veterans' at the bottom of this vacancy for further documentation requirements for Veterans.
Entrance on Duty Requirements (EOD): If you are unable to complete all of the pre-employment requirements within 90 days from the date of the Clearance Instruction Letter (CIL), the FAA may rescind your tentative job offer for this vacancy. If you are a current military member in active duty service, you must submit a copy of your DD Form-214, or written documentation (certification) from your branch of service certifying that you are expected to be discharged or released from active duty under honorable conditions no later than 120 days after the date the certification is signed.
Age Requirements:
A maximum age of 30 years is established for initial entry into air traffic control positions covered by Public Law 92-297. Persons who have reached their 31st birthday may not be originally appointed to these positions. If experience was gained as a civilian ATCS with the Federal Aviation Administration (FAA) or Department of Defense (DOD), you must have been hired prior to age 31. Please see the Required Documents section of this announcement for further information on specific documentation that MUST be provided if you were previously hired by the FAA or DOD prior to the maximum entry age for this position
Education
Applicants who are using education as a qualifier must submit a copy of the official/unofficial transcripts to substantiate all credit hours and/or confer date.
Preview Job Questionnaire
Make sure your resume includes detailed information to support your qualifications and answers to the job questionnaire.
Additional information
We may use this vacancy to fill other similar vacant positions.
Position may be subject to a background investigation.
A one-year probationary period may be required.
The person selected for this position may be required to file a financial disclosure statement within 30 days of entry on duty. FAA policy limits certain outside employment and financial investments in aviation-related companies.
This position is covered by the Department of Transportation's Drug and Alcohol Testing Program. Any applicant tentatively selected for this position will be subject to pre-employment or pre-appointment drug screening. Persons occupying a "testing designated position (TDP)" will be subject to random drug and/or alcohol testing.
All applicants found qualified for the position will be required to take and pass the Air Traffic Skills Assessment (AT-SA):
Links to Important Information: Locality Pay , COLA
How You Will Be Evaluated
You will be evaluated for this job based on how well you meet the qualifications above.
IMPORTANT: Applicants may be rated on the extent and quality of experience, education, and training relevant to the duties of the position(s). All answers provided in the on-line process must be substantiated. Ensure that your application package/resume supports your responses.
Background checks and security clearance
Security clearance
Public Trust - Background Investigation
Drug test required
Yes
Required Documents
Applicants qualifying based on education must submit a copy of the official/unofficial transcripts to substantiate all credit hours and/or confer date.
Applicants who do not meet one of the waivers to maximum entry age to be considered, but have previous 2152 experience and are past the maximum entry age of 31, MUST provide a copy of a Notification of Personnel Action (SF-50) that verifies original appointment to the civilian 2152 occupational series prior to reaching the maximum entry age of 31. This would be the initial Notification of Personnel Action (SF-50/new-hire action into the 2152 series) received from your servicing Federal Human Resources office.
If you do not have a copy of your initial Notification of Personnel Action (SF-50/new-hire action into the 2152 series), you can request it through the National Personnel Records Center at the following link: Official Personnel Folders (OPF), Archival Holdings and Access
Service Computation Dates (SCD's) cannot be used for maximum entry age verification purposes, as this could include prior military service and/or current or previous federal civilian service in another occupational series.
Facility rating records issued by the FAA or military issued ratings and/or training records must be provided, if qualifying based on specialized experience or one of the alternative requirements.
Applicants qualifying under VRA must provide either a DD Form 214 Certificate of Release or Discharge from Active Duty (Member 4 Copy or equivalent), OR a document from the armed forces certifying that within 120 days you are expected to be discharged or released from active duty.
All Veterans: If you are claiming veterans' preference, you must submit either a DD Form 214 Certificate of Release or Discharge from Active Duty (Member 4 Copy or equivalent), or a document from the armed forces certifying that within 120 days you are expected to be discharged or released from active duty service under honorable conditions. If you are claiming 10 point preference, you must also submit a completed SF-15, Application for 10-Point Veteran's Preference, and supporting documents outlined on the SF-15. Documents must be uploaded or faxed to the Servicing Human Resource Management Office listed in this announcement and all documents must be received by the closing date of the announcement. If you fail to submit documentation, you will be assessed as a non-veteran.
If you are claiming 10 point preference but fail to submit the supporting documents outlined on the SF-15, you will be tentatively assessed as a 5 point preference eligible provided your DD Form 214 reflects that you have the service required to qualify for preference. Documents must be uploaded or faxed to the Servicing Human Resource Management Office listed in this announcement and all documents must be received by the closing date of the announcement. If you fail to submit documentation, you will be assessed as a non-veteran.
Veterans currently on active duty claiming veterans' preference: You will be granted tentative preference if you submit a document from the armed forces certifying that within 120 days you are expected to be discharged or released from active duty service under honorable conditions and your application shows that you have the required service. Prior to being appointed, you must provide to the Servicing Human Resource Management Office a DD Form 214 documenting discharge/release and showing that the service was honorable or general. If you are on terminal leave, you must provide documentation certifying authorized terminal leave.
If you are relying on your education to meet qualification requirements:
Education must be accredited by an accrediting institution recognized by the U.S. Department of Education in order for it to be credited towards qualifications. Therefore, provide only the attendance and/or degrees from schools accredited by accrediting institutions recognized by the U.S. Department of Education.
Failure to provide all of the required information as stated in this vacancy announcement may result in an ineligible rating or may affect the overall rating.
Benefits
A career with the U.S. Government provides employees with a comprehensive benefits package. As a federal employee, you and your family will have access to a range of benefits that are designed to make your federal career very rewarding. Learn more about federal benefits.
Review our benefits
Eligibility for benefits depends on the type of position you hold and whether your position is full-time, part-time, or intermittent. Contact the hiring agency for more information on the specific benefits offered.
How to Apply
You must apply online to receive consideration. Your application must have a status of "Received" by 11:59 PM Eastern Time on the Close Date for it to be accepted. If you are applying for positions associated with FAA registers, your application must have a status of "Received" each time a referral list is created in order to receive consideration for positions associated with register.
IN DESCRIBING YOUR WORK EXPERIENCE AND/OR EDUCATION, PLEASE BE CLEAR AND SPECIFIC REGARDING YOUR EXPERIENCE OR EDUCATION.
We strongly encourage applicants to utilize the USAJOBS resume builder in the creation of resumes.
Please ensure EACH work history includes ALL of the following information:
You may upload completed documents to your USAJOBS Account. This will provide you the opportunity to utilize the uploaded information again when applying for future vacancies. Please see this guide, Document Upload Guide, for more information on uploading and re-using the documents in your applications.
Forms:
Agency contact information
Aviation Careers
Phone
(405) 954-4657
Fax
(405) 954-5766
Email
[email protected]
Address
Aviation Careers
6500 South Mac Arthur Blvd.
Oklahoma City, OK
US
Learn more about this agency
Next steps
Candidates for FAA positions are evaluated using our Automated Vacancy Information Access Tool for Online Referral (AVIATOR) system. AVIATOR compares your skills and experience as described in your application with the requirements of the position. If you are found to be an eligible, highly-qualified candidate, you will be referred to the selecting official for further consideration. (In some cases, individuals with priority for special consideration must be considered and selected before other candidates.) Whether or not you are contacted for an interview depends upon the location of the position and the judgment of the selecting official.
Important - If you make any change to your application, you must resubmit it. If you change your application and do not resubmit it, your changes will not be considered part of your application package, and your previous application will be considered.
All qualified applicants will be considered regardless of political affiliation, race, color, religion, national origin, gender, sexual orientation, marital status, age, disability, or other non-merit factors. DOT provides reasonable accommodations to applicants with disabilities. If you need a reasonable accommodation for any part of the application and hiring process, please notify us. Decisions on granting reasonable accommodation will be made on a case-by-case basis. Additional information on reasonable accommodations procedures or on EEO Programs is available on Office of Civil Rights (ACR) or by contacting the local FAA Civil Rights Office.
Overview
- Open & closing dates
06/19/2018 to 06/26/2018 - Service
Excepted - Pay scale & grade
FG 1 - Salary
$24,086 to $30,134 per year
This salary includes locality pay which will be applicable while attending the FAA ATC Academy.
- Appointment type
Temporary - Temporary NTE - 13 months - Work schedule
Full-Time
No
Telework eligible
No
This job is open to
Apply
Announcement number
Control number
502735700
Duties
Summary
Responsibilities
- Complete occupational indoctrination including highlights of Federal employment, familiarization with organizational structure & functions, aircraft, air traffic control system, & aviation industry, classroom instruction & workshop exercises relating to the air traffic control system.
- FAA Radar Training
- TRACON Skills Enhancement workshop
- Advanced TRACON skills training focusing on skills required for success at New York TRACON
Travel Required
Supervisory status
No
Promotion Potential
1
Job family (Series)
Similar jobs
Requirements
- US Citizenship is required.
- All applicants must pass the Air Traffic Skills Assessment (AT-SA) Exam.
- Area of consideration: must reside within a 50 mile radius of Westbury, NY/N90 TRACON.
Qualifications
- TO QUALIFY BASED ON PROGRESSIVELY RESPONSIBLE WORK EXPERIENCE: applicants must document 3 years of full time (40 hours per week) progressively responsible experience. Most types of paid or unpaid employment will provide progressively responsible experience as the individual doing the work learns about the organization, gains knowledge about the work, and demonstrates responsibility. OR
- TO QUALIFY BASED UPON EDUCATION: applicants must document a full 4-year course of study leading to a Bachelor's degree. Schools must be accredited by an accrediting institution recognized by the U.S. Department of Education. If qualifying based on education, applicants must submit a copy of the transcript which includes the name of the institution, quarter or semester hours earned and/or confer date. OR
- TO QUALIFY BASED UPON THE COMBINATION OF BOTH WORK EXPERIENCE AND EDUCATION: The applicant's total qualifying experience is converted to a percentage of the experience required then the applicant's education is converted to a percentage of the education required. The combined percentages must equal 100%. At the undergraduate level, successfully completed education that has not led to possession of a degree is credited based on its relationship to 120 semester hours or 180 quarter hours. For example, 30 semester hours or 45 quarter hours is comparable to 1 year of undergraduate education. For study at a business or technical school, 36 weeks of study (20+ classroom hours per week) is comparable to 1 academic year above high school. OR
- TO QUALIFY BASED ON SPECIALIZED WORK EXPERIENCE AS AN AIR TRAFFIC CONTROL SPECIALIST: applicants qualifying based on specialized experience must provide supporting documentation that verifies that this requirement has been met (e.g., FAA certificate, military certificate or training record). OR
- TO QUALIFY BASED ON ALTERNATIVE REQUIREMENTS: applicants must provide supporting documentation that verifies at least one of the following alternative requirements being met: a. Do you hold or have held an appropriate facility rating and have actively controlled air traffic in civilian or military air traffic control terminals or centers? b. Do you hold or have held an FAA certificate as a dispatcher for an air carrier? c. Do you hold or have held an instrument flight rating? d. Do you hold or have held an FAA certificate as a navigator or have been fully qualified as a Navigator/Bombardier in the Armed Forces? e. Do you have 350 hours of flight time as a copilot or higher and hold or have held a private certificate or equivalent Armed Forces rating? f. Have you served as a rated Aerospace Defense Command Intercept Director?
- Disabled veterans; or
- Veterans who served on active duty in the Armed Forces during a war, or in a campaign or expedition for which a campaign badge has been authorized; or
- Veterans who, while serving on active duty in the Armed Forces, participated in a United States military operation for which an Armed Forces Service Medal was awarded; or
- Recently separated veterans (defined as; within the last 3 years).
Age Requirements:
Education
- Travel to & from testing locations will be at the expense of the applicant.
- Applicants may check their USAJOBS account to get updates on the status of their application after the announcement closes. Applicants who set up their USAJOBS account to provide email updates will receive an email notification with any change in status of their applications.
- Requirement for pre-employment medical clearance: Applicants selected for ATCS positions must pass a medical examination that includes psychological screening prior to appointment. Applicants with prior military service are encouraged to obtain a sealed copy of their military medical records prior to discharge and to retain these records to be provided upon request if selected.
- Requirement for security clearance: This position requires an Access National Agency Check and Inquiry with Credit (ANACI) or higher prior to appointment unless a waiver is obtained.
- Training Requirements: After successful completion of Academy training, the ATCS will enter the appropriate phase of field training as determined by the assigned facility to prepare for advancement to the Certified Professional Controller (CPC) level. They must learn the skills needed for operation at higher levels of responsibility.
- Successful certification at assigned FAA facility is required. Failure to certify will result in separation, demotion or reassignment.
- Requirement for nonstandard duty hours or work week: Incumbent may be required to work irregular duty hours or a nonstandard work week or tour of duty.
Security clearance
Drug test required
Yes
Required Documents
Benefits
Review our benefits
How to Apply
- Job Title (include series and grade if Federal Job)
- Duties (be specific in describing your duties)
- Employer's name and address
- Supervisor name and phone number
- Start and end dates including month, day and year (e.g. June 18 2007 to April 05 2008)
- Full-time or part-time status (include hours worked per week)
- Salary
Forms:
- SF-15 : Application for 10-Point Veteran Preference
Aviation Careers
Phone
(405) 954-4657
Fax
(405) 954-5766
[email protected]
Address
Aviation Careers
Oklahoma City, OK
US
Next steps
