Thanks for the infoThey stop using you for staffing as soon as you put in the paperwork. I was at my old facility within 5 days of approval.
For your purposes, the staffing number should be locked in once you Submit your paperwork. We had a supe Bid not need a deviation Bc when he bid, we were good. By the time he got hired we lost 4 or 5, but Bc the SWB was locked in at his bid, he was able to go no issuesDoes anyone know when the numbers freeze for your previous facility's projected number? When I submitted the paperwork to withdraw and FastTrack back, my previous facility was below 100. They have since gone above 100 due to direct hires. I'm hearing both answers from higher ups.
I say should Bc I have no doubt the agency likes to use that reasoning when it benefits them. But you’d have a good case to for a grievance or even a lawsuit if they play games.
Trying to get a clarification on this. If you withdraw, the second you submit for the nest panel or apply to fastrack back to your original facility, they will no longer be able to use you for staffing?They stop using you for staffing as soon as you put in the paperwork. I was at my old facility within 5 days of approval.
That is the way the rule is written but I I would at least one case where someone officially washed out and they are forcing him to continue to work to help them maintain their reduced work schedule, which is hilarious lol.Trying to get a clarification on this. If you withdraw, the second you submit for the nest panel or apply to fastrack back to your original facility, they will no longer be able to use you for staffing?
That's ridiculous. I could maybe see a withdrawal, but definitely not a termination.That is the way the rule is written but I I would at least one case where someone officially washed out and they are forcing him to continue to work to help them maintain their reduced work schedule, which is hilarious lol.
It was technically a withdrawal but it’s supposed to be treated the same as a termination.That's ridiculous. I could maybe see a withdrawal, but definitely not a termination.
A wash is a wash.It was technically a withdrawal but it’s supposed to be treated the same as a termination.
did this person want to work or no? Seems like that is mighty dicey territory regardless of termination or withdrawal to have someone continue to work when they do not want to be working at that facility. If something happens then it's completely on the FAA putting someone in a position where they are not CPC and do not want to be an employee there.It was technically a withdrawal but it’s supposed to be treated the same as a termination.
We’ve had withdrawals who continue to work FD/CD, but I don’t know if they offered to do that or were told to do that.
is FDCD eligible for OT there?
not anymore cause we have so many but used to be 6 day weeks starting the day you got it
