Article 61, Section 2, Paragraph 2
Anyone have some clarification on this, so far as I'm reading it it says if a developmental washes out and is passed probation they should be offered a lower level facility if there is a vacancy there..
Depends on the level and type of facility. A couple D-sides at a center, then either fail or withdraw from training, and you'll get low level tower only facilities to pick from. In radar training at a low-level up/down and don't make it...same thing, lower level towers. Don't make it at a level 5 tower only on local...and it's a little more dicey, but I know of people sent to Level 4 towers. Don't make it on ground at that level 5 tower, and odds are you'll be removed from the FAA, given Flight Data somewhere, or Flight Service in Alaska.Article 61, Section 2, Paragraph 2
I just got recommended today for radar at my level 5 up/down. Hypothetically speaking, if I were to withdraw from training, they would for sure retain me and send me to a level 4 tower only?Depends on the level and type of facility. A couple D-sides at a center, then either fail or withdraw from training, and you'll get low level tower only facilities to pick from. In radar training at a low-level up/down and don't make it...same thing, lower level towers. Don't make it at a level 5 tower only on local...and it's a little more dicey, but I know of people sent to Level 4 towers. Don't make it on ground at that level 5 tower, and odds are you'll be removed from the FAA, given Flight Data somewhere, or Flight Service in Alaska.
The higher the facility level and the further you make it in training, the better your facility choices from the NEST will be.
It's not 100% for sure, but a level 4 tower would be likely maybe level 5 depending on which ones need people.I just got recommended today for radar at my level 5 up/down. Hypothetically speaking, if I were to withdraw from training, they would for sure retain me and send me to a level 4 tower only?
Stinger, Man, it's so tempting knowing that I'm going to be stuck here for a minimum of 2-3 years. I don't want a failure/withdrawal on my resumé and i could not, in good conscience, bail on the people that put their time and effort in to training me. It just sucks because I love this job and really want to work busy traffic but I control at an airport that undoubtedly has no need for atc. We could easily be a ctaf. Only average 43 ops/day in the tower. On most days we can't even fill up 10 arrivals and 10 departures within the last 24 hours on flightaware.
Find a hobby to do to make your time at work more enjoyable. Read, knit, crochet, go outside and hit a tennis ball against the wall. Walk laps or go talk to pilots and find a friend. Just find something and work will be more enjoyable.
