CookieMonster
Do Trainees at your facility have weekends as RDO? Or is it not available because they haven't earned the rights to have Sat/Sun off?
If the schedule can support it why wouldn't they get it off?earned the rights to have Sat/Sun off
Trainee RDOs are set up to align with available trainers and traffic. Nobody talks about trainees not deserving certain days off like they haven’t earned it. They are training and have no say.
Not in any of the 4 facilities I’ve been to. Less trainers on the weekend would make it more likely to get a weekend off RDO set right? Conflicting points there.The weekends are viewed as just as busy as the rest of the week, if not, then less busy. There are also less trainers that work on the weekends, because it is a younger group of controllers who are not yet qualified. This is for a facility with 7+ trainees. So without having Sun/Mon, Sat/Sun, Fri/Sat, for Trainees to select from, the other lines have 2+ trainees to accommodate.
Upon discussion, general consensus at the facility is that others worked for years for the weekend RDOs, so it is not right to have it without being CPC.
Wanted to see if any other facility also...operate the same way.
Probably nothing until you run for rep or sup lol.Exactly! But if it made sense, and trainees had RDOs that followed the lines with the most trainers, they would end up with weekends off, which is a no no. ATM & Natca Rep agrees to it, so not sure what can be done.
But know your reps and management are total D bags.
Definitely NOT a country club.Upon discussion, general consensus at the facility is that others worked for years for the weekend RDOs, so it is not right to have it without being CPC.
The best is when the class after you gets all these prime RDO slots that didn’t exist when your class went to the floorWe bid D-sides and R-sides separately based on seniority. So I was able to get Fri/Sat off.
