IQTR class pass rate
147 replies · 31,426 views · Page 7 of 8
  1. SunnyATC #121
    JohnMadden said:
    Everyone who is talking about level caps for transfer are absolutely ridiculous. So it should be up to the luck of draw on whether or not you get sent to a 10,11, or 12 Z fresh out of the academy but if you get terminal and go to a 4,5, or 6 you should be capped and take a decade minimum to get to a 12 when considering training and transfer times? If you get assigned a low level facility off the rip you should have the opportunity to go to a high level. Many do and many are making it through training successful. I do agree changes need to be made to help the mid level facilities but limiting our transfer power is idiotic.
    Well if people from mid level facilities could get released it wouldn’t be an issue. Why should a busy TRACON only facility be selecting ERRs from level 4/5 tower only while candidates from mid level radar facilities are understaffed and ineligible for transfer?
  2. 32andBelow #122
    KP-ATC said:
    It never was.
    There was a time were it was harder to get the low fee funds
  3. Hope #123
    1/22 IQTR Class List
    Cat B: ZSU BOI SAT M03 BHM ICT CRP SDF
    Cat C: A11 U90 JCF Y90 JAX PBI RSW SAV HCF IND CVG MSY AZO T75 R90 ABQ CMH OKC TUL PIT CHS MYR TYS AUS GEG
    Class finished 13/13. Picked:
    1 ABQ Volunteer
    1 JCF Volunteer
    1 ZUA Volunteer
    2 PBI
    2 RSW
    BOI
    GEG
    BHM
    PIT
    HCF
    From the ATC Academy & Hiring Discord
  4. SquawkHijack #124
    32andBelow said:
    You should just move up a level on the pay bands after you spend 7 years at a facility
    I’m assuming this is an indictment on Article 100, which is only valid for facility in-grade or downgrade transfers (so if you’re at a 4 or 5 you’re basically fucked) and eligible after 8 years CPC time at present facility. A very stark difference to Article 124 for 15 years at 10-12s. An in-grade/downgrade could mean anywhere you want to go that has a chair for you to sit in.
    Cpt_munky said:
    Also I put in for about 14 different level 9 up downs and I'm still trapped because ncept releases to the 11s and 12s when you do get a release, not to the 9s
    This is an underrated comment. Yes, since new hires can get country club mid levels now we as controllers should partially kick ourselves in the ass for so many of us filing paperwork to jump straight to 10-12s. BUT, it takes two to tango, anyone CAN file to go anywhere but it’s the agency that approves so many of these bottom-to-top ERRs and let understaffed 8s/9s sit on their middle finger.
  5. Cpt_munky #125
    Ok so you're arguing against this. Here is the reality: if you get forced to a mid level or if the academy you'll be stuck for ten years trying to get to a high level.
    You'd rather keep the system that fucks the mid level people.
    I would rather build a pipeline to alleviate the problem with staffing mid level facilities that forces people to be stuck.
    If 4,5, and 6 level controllers can only transfer to 7,8, and 9 respectively then those facilities will get staffing that has previously struggled. Those that have put in their time working actual traffic should be rewarded with the opportunity to leave.
    Instead we have level 5 controllers that don't do any real work moving to Cookie cutter level 12 facilities that do high volume low complexity.
    The ones doing the work get fucked.
  6. Hope #126
    2/12 IQTR List
    Cat B: M03 BOI SAT BHM CRP ICT
    Cat C: A11 U90 JCF Y90 JAX P31 RSW SAV HCF IND CVG SDF MSY AZO T75 R90 ABQ CMH OKC TUL P80 PIT ZSU CHS MYR AUS MKE
    Class finished 11/13. Picked:
    A11
    ZSU x2
    HCF x2
    MYR x2
    AUS
    BOI
    P80
  7. Hope #127
    2/20 IQTR LIst
    Class Finished 11/12. Picked:
    x2 BOI
    x2 P80
    x2 AUS
    A11
    Y90
    JCF
    MYR
    M03
  8. Hope #128
    3/10 IQTR List
    Cat B: M03 SAT CRP ICT BHM MSY BOI
    Class finished 10/12. Picked:
    x2 RSW
    CVG
    Y90
    SAV
    BOI
    SAT
    ABQ
    M03
    P31
  9. Hope #129
    3/19 IQTR List
    Cat B: SAT M03 ICT BHM CRP MSY BOI SDF
    Cat C: A11 U90 JCF Y90 JAX RSW SAV HCF IND CVG AZO T75 R90 ABQ CMH OKC TUL PIT ZSU CHS MYR AUS MKE
    Class Finished 10/13. Picked:
    OKC
    JCF
    JAX
    SAV
    R90
    TUL
    ABQ
    BHM
    M03
    SAT
  10. Hope #130
    3/19 N90 Track
    Class finished 6/8. Picked:
    N90 x6
  11. Hope #131
    4/3 IQTR List
    Cat B: SAT M03 ICT BHM BOI CRP MSY SDF
    Cat C: A11 U90 JCF Y90 JAX SAV HCF IND CVG AZO T75 R90 ABQ CLE OKC TUL PIT ZSU CHS MYR AUS MKE
    Class finished 13/15. Picked:
    ABQ
    U90
    CMH
    JCF
    R90 x2
    SAV x2
    MKE x2
    SDF
    CRP
    SAT
  12. NightWatch #132
    We had that for sure, now absolutely none of the low level up/downs can release thanks to this scheme called CRWG. And then the agency wants to send OTS hires to 8s & 9s because they’re somehow systemically disadvantaged to get staffing so a specially tailored academy pipeline was created just for them… make this fucking make sense.
  13. ClearanceClarence #133
    Id be curious to see the facility training data on this hiring track. The Academy pass rates have been insane compared to Enroute and Terminal, it’s almost like they’re intentionally letting more people pass. But then if half these kids are washing out at their first facilities, it completely defeats the purpose.
  14. boilergirl87 #134
    Our facility, personally, is 2/5 right now. One is done with radar and is training in the tower, the other just started her 3rd radar position and is doing well. 2 of the washouts didn't make it out of SIMs (1 was terminated the other went into the NEST), the 3rd was terminated after being unsuccessful in certifying on 1 radar position - less than 2 weeks away from being off of probation.
  15. ATOH #135
    The big issue with IQTR is the graduates come in with no basic fundamentals in ATC. 8s/9s are better suited to training techniques on running traffic in a particular airspace
    They aren't designed teach trainees things like proper phraseology and how to radar identify somebody, etc. Not allowing them to train in the tower environment first isn't doing them any favors. There are obvious exceptions and better trainees but its really not a good hiring track that sets people up for any kind of success.
  16. NightWatch #136
    The military faces the same pitfall when career field staffing sucks. Some officer tells a lower ranking officer to fix it so they lower standards some at the ATC school house. Everytime it just results in more peeps washing at first facilities and changes nothing lol. What a paradox.
  17. NightWatch #137
    They aren't designed teach trainees things like proper phraseology and how to radar identify somebody, etc. Not allowing them to train in the tower environment first isn't doing them any favors. There are obvious exceptions and better trainees but it’s really not a good hiring track that sets people up for any kind of success.
    Hell, it’s the FAA. They don’t care about setting anyone up for success, even themselves.
  18. Hope #138
    5/15 IQTR List
    Class B: ICT M03 BOI BHM MSY SAT SDF CRP JAX
    Class C: A11 U90 Y90 P31 HCF IND CVG AZO T75 ABQ CLE OKC TUL PIT ZSU MKE
    Class finished 14/14. Picked:
    T75 x2
    BHM
    BOI
    HCF (volunteer)
    MSY (volunteer)
    Y90
    ZSU x2 (volunteers)
    A11
    PIT x2
    P31
    M03
  19. Cpt_munky #139
    Would you like a fork, or a spoon to eat your words with?
    CRWG is dead: long live CWP I guess. Make this fucking make sense? Am I doing it right? Idk wtf is happening
  20. Hope #140
    5/22 IQTR List
    Cat B: BOI M03 BHM SDF MSY JAX
    Cat C: U90 Y90 HCF IND CVG AZO T75 ABQ CLE OKC PIT ZSU CRP MKE
    Class finished 12/13. Picked:
    x2 BOI
    x3 U90
    M03
    BHM
    Y90
    IND
    T75
    JAX
    JCF
