Shows OKC has two ERR outbound? Am I reading that correct?Couldn't upload the PPT and ERR demand sheet in the XLSX format, but here they are converted to PDF.
Yes. 2 people are trying to leave. They each only put in for 1 facility. Unfortunately you guys can't release this panel.Shows OKC has two ERR outbound? Am I reading that correct?
Ah got my hopes up. I’m one of the people trying leave lolYes. 2 people are trying to leave. They each only put in for 1 facility. Unfortunately you guys can't release this panel.
Hopefully you can get out before your staffing number jumps by 6.Ah got my hopes up. I’m one of the people trying leave lol
Yeah I don’t think I am. They just put out an SOI for a temp supe.Hopefully you can get out before your staffing number jumps by 6.
Make sure your fac rep tells them to pound sand.Yeah I don’t think I am. They just put out an SOI for a temp supe.
You take 1 and divide it by the cpc target number. For the case of A11, each CPC is 1/24, or 4.16% towards the projected. Every trainee is equal to 1 cpc multiplied by the training success rate. So for every new trainee A11 gets, the projected goes up by (.0416*.809) = 3.37% until they either certify or washout.PPT question. When it comes to projected % to target, is each NCEPT addition worth 1 full body? Or is each one worth 1 x training success rate? For example, A11 each NCEPT add is worth .809 controllers.
Yes. There are a lot of other factors though. Like where you rank, if your facility releases round 1, staffing levels, projected to target versus national average, etcQuestion:
The facility that I put paperwork in for is just above 90%. If they lose one in round one could they pick me up in round 2?
No, the other response is wrong. The numbers are locked in before the panel and are not adjusted during the panel so if a facility is projected 90% at the start of the panel, they will not be picking anyone up in round 2.Question:
Tell us which facility and I’ll tell you how to remove itCan you remove an ERR this close to NCEPT convening? I’d like to avoid a certain facility that I put in for. Is it too late?
I’d let your ncept rep know asap. And email the poc for the region you filed forCan you remove an ERR this close to NCEPT convening? I’d like to avoid a certain facility that I put in for. Is it too late?
There's instructions on ksn on how to do it. You have to email 3 people and the HR region you submitted to I believe.Can you remove an ERR this close to NCEPT convening? I’d like to avoid a certain facility that I put in for. Is it too late?
You can. Send an email to your HR region, Shallenberger, Devine, and Pla. In “theory” you can remove paperwork all the way up until they convene the panel. Contact your NCEPT rep if you need more detailed instructions.Can you remove an ERR this close to NCEPT convening? I’d like to avoid a certain facility that I put in for. Is it too late?
