No. 20 years minimum in the FAA before you’re eligible for retirement.If I Have 15 years military service and do 15 years ATC service in the FAA would I be eligible for a 30 year federal retirement?
If I did 20 for the FAA would I be eligible for the 1.7 for all 35 years,(30 year retirement at 1.7) or would it be the 1.7 for the ATC years and 1% for the military?No. 20 years minimum in the FAA before you’re eligible for retirement.
I understand that military time is 1 percent, but it doesn't say if it counts towards your retirement in years. If you are over 30 years federal time you are eligible for a standard FERS retirement (non atc) of 1.7 percent for all 30. The question more or less is if your military time counts to push you to that 30 , or is just worth the flat 1% regardless of yearsThis is super easy to Google. 1.7% for 20 years of federal ATC. Anything beyond that including military time (if you bought that time back) is 1%.
If you buy back those 15 years military service, you can technically retire after 10 years in the FAA since you’ll meet the 25 year requirement, so to answer your question, yes you can (if you buy that time back). If you buy your time back, your entire time combined will be calculated off of your high-3 and 20 years will be at 1.7%, the remaining at 1%If I Have 15 years military service and do 15 years ATC service in the FAA would I be eligible for a 30 year federal retirement?
19 years of military service and 1 year of FAA service deems the individual eligible for retirement? Wow.If you buy back those 15 years military service, you can technically retire after 10 years in the FAA since you’ll meet the 25 year requirement, so to answer your question, yes you can (if you buy that time back). If you buy your time back, your entire time combined will be calculated off of your high-3 and 20 years will be at 1.7%, the remaining at 1%
No, not 19 + 1, it’s either 20 years FAA ATC or 25 cumulative federal service19 years of military service and 1 year of FAA service deems the individual eligible for retirement? Wow.
Bought back military service is only used to add to the retirement pay calculation. It is never used for good time/eligibility. The exception for when military service is creditable is when already a federal employee and getting concurrent military service (ie: guard unit being activated, title 32 position, etc.).Any length of military years after entering civilian service (that are bought back) would then count towards the 25 year eligibility to then retire.
I guess thats a better way to address the question, I knew it wasnt good for ATC retirement, but I wasnt sure if the time could be used for general federal cumulative time(not atc special but GS general equivalent) or if it was only added for post retirement calculations cumulative federal serviceBought back military service is only used to add to the retirement pay calculation. It is never used for good time/eligibility. The exception for when military service is creditable is when already a federal employee and getting concurrent military service (ie: guard unit being activated, title 32 position, etc.).
Permission to have my initial response as being “correct” and closing out this thread? God, I love being me.Bought back military service is only used to add to the retirement pay calculation. It is never used for good time/eligibility. The exception for when military service is creditable is when already a federal employee and getting concurrent military service (ie: guard unit being activated, title 32 position, etc.).
All great info! I’d like to add that you CAN actually work past 56 years old AS LONG AS you have not yet completed 20 years of FAA ATC service, which THEN you would hit your mandatory retirement time.Now some downsides. As a controller you will have to be retired by the end of the month in which you turn 56. Therefore, getting to your MRA would require at least one more year worked in another government job.
