Here's a complete and utter surprise: An FAA document was written by idiots who don't know how to use the English language, and as a result it is unclear and may not mean what the authors wanted it to mean. Or else you're interpreting it wrong. Either option is entirely possible.
This has happened, soo.... what's your point?
If the workgroup intended for a training team recommendation to be a
prerequisite in order to conduct a CSC, they should have said so in so many words. As written, a recommendation is not necessary.
This is a bad take, and here's why.
Here's the entire text of the 3120.4 paragraph 8a:
The document is not, as I said, an example of good and clear English, which is why you're interpreting it in a manner inconsistent with the actual words on the actual page.
The problem with your reading of the paragraph is that you're treating the listed items as, well, a list. A single list must contain either all AND-items or all OR-items; if some are AND and some are OR then you need to break the list into separate sub-lists that each contain only similar items.
So if you're treating this collection of clauses as a single list, you have to see that 4 through 8 are obviously supposed to be AND-items; you can't say "this CSC was conducted via direct monitoring during normal workload conditions,
therefore I don't have to review OJT documents nor document it on the appropriate form." That would be a stupid and clearly incorrect interpretation. But if you interpret it that way, then items 1 through 3 must be AND-items as well—which is clearly incorrect. They aren't trying to say that you can
only perform a CSC once you have a training team rec
and run out the target time
and run out the supplemental time.
So now you have a conflict, and because you have a conflict you have to break it up. You have to treat 1 through 3 as being somehow different from 4 through 8. You look down to paragraph 8b, which helpfully tells you that the CSC
may be conducted at any time past minimums and
may be performed before running out supplemental or additional time.
Now you can try to take a more narrow view, and say that 8a(1) always applies, and that 8b(1) only waives 8a(2) and 8b(2) only waives 8a(3). But there's no specific wording or formatting to indicate that, so you're already reading more into the words than what's actually there, and you have possibly conflicting readings of what the words say (as evidenced by our disagreement here). The only real solution is to have the document re-written to be unambiguous.
Here's how I would re-write it, if my and
DADDYSbabyBIRD's interpretation is the intended meaning:
And here's how I would re-write it if your interpretation is the intended meaning:
See how either of those re-writes would make the meaning clear? I've broken the requirements into two categories: "Must conduct CSC once this happens" and "must not conduct CSC until this happens." The current document jams both categories into the same list without distinguishing them.
