FightingIrish2012
That’s a pain in the ass going forward, I’ll do it next week though.you'd have to get your info from your ATM
Unfortunately you didn't CPC at the level 8, not did you CPC at the level 7. Two failures in a row (and hardshipping before reaching CPC is considered a failure) has always carried the possibility of not being retained. The FAA does not concern itself with military or DOD time. So in the FAA's eyes you only ever certified at a level 5 and then failed twice. While they could have potentially offered you level 4/5 towers it is possible that they're all fully staffed. Sorry to be the bearer of bad news but it doesn't look good for you. I suppose in theory if you were certified at your 5 for more than a year maybe you could resign and reapply to a prior experience bid... Or I suppose you could using your DOD time. Not sure if they would accept you though.Here's my situation. I washed out from a level 8 tower. Previously, I was at a level 7 up/down but had to do a medical hardship. At that level 7, I got qualified in the tower on LC,GC/FD but didn't get to start CIC training. In radar, I got FD and started 1 scope but training was stopped, when the ATM got wind that I was going to hardship.
I haven't got anything officially but I'm being told by my Fac Rep that on Monday I will be receiving the decision for removal or to accept an AT 2154 position. Apparently this is also occurring to a few others from adjacent facilities and my rep also mention that some he knows got the same notice but I don't know that persons background/situation.
I wasn't expecting this as the outcome, I was expecting a list of low level tower only. The TRB, ATM and Fac Rep all recommended retention. I realize it doesn't mean much to most in the FAA but I worked several DOD ATCTs through out a 10 year period and did qualify in a level 5 FAA ATCT, level 7 without the TRACON. So my options are accept the AT 2154 or removal. If I turn down the AT 2154 position, NATCA can try to do a rebuttal but it not guaranteed to keep me employed as a 2152 and I will no longer have the option for the AT 2154 position. The removal process will start and then I can try to fight it out by hiring an attorney and going through the merit systems protection board/MSPB after I'm terminated from the agency.
I'd appreciate any suggestions because I don't really know what is my best approach to this.
Hope those of you waiting get better news.
Data specialist at a center would have to be better than a remote Alaska FSS location. Might be worth checking out. Easy enough to bail if you don’t like it.I was also given retention to FSS, but no FSS positions available. So removal from ATC. They offered to let me potentially transfer to a center to be a 2154 Flight Data Communications Specialist. I was AG sent to a level 6 up/down and didn't certify on local. Both ATM and FACREP recommended lower level facility but this is where I'm at now as well.
Is 2154 both flight service and flight data?
Is it the same good time?
I truthfully don't know but if I had 5 years until a pension I'd tough it out anywhere
Any facility certification resets the fake 2 strikes rule. If you transfer as a CPC and wash or withdraw you can go back to your old facility if it is not above 100% projected staffing. If it is you go to the NEST, and you can choose to go to the NEST as well (and if your old facility is not at 100% projected staffing it should also be on your NEST list).I’m sorry to hear about your situation, hoping for the best outcome for you. Hope you can get those last 5yrs without much trouble.
Question for the group. If a current CPC ERRs to a new facility and washes there, can they return to their old facility or do they go directly to the nest? The only way you “may” be terminated is having 2 failures back to back, without CPC status in between. If you CPC again somewhere (even previous facility) it resets the 2 strike rule? Am I understanding this correctly?
Not making info public because they have to make room for hundreds of washouts from n90
