KP-ATC said:
Why? Class B is positive control airspace. Use of view limiting devices is riskier in class D where airborne aircraft aren't separated from each other.
By design, Class B is also very restrictive airspace toward VFR operations for a reason, it’s usually very busy with a lot of higher performance aircraft in close proximity. And since it would be pretty pointless (and illegal) to operate under IFR while using NVGs, I’m just saying, there are LOTS of better places to practice this. How many real world military night ops are going to be in an environment like a busy bravo where you’re dodging airplanes?
I understand that the military needs to train, but this in particular would be like a Piper Cherokee wanting to come into a bravo airport and do touch and gos during periods of moderate to peak traffic. It would be unreasonable, unsafe and most likely denied by ATC in many instances. I think the same nature should apply to the use of NVGs contributing to the incident at DCA.
ManBearPig said:
Im okay with it a long as there is a safety pilot. I agree maybe both pilots in our UH60 case should not be under NODs. If they want to train like they fight, put 1 with and 1 without.
I would generally agree with that, as is a typical practice among military aircrews. Problem is, there are lots of single piloted military aircraft that operate under NVGs as well. The A-10 being an example.
Plus, I don’t foresee the military conducting a whole lot of real world night ops in an environment like a bravo where there’s a good chance they’ll be maneuvering in close proximity to lots of other aircraft. I also agree with you to train like you fight, but I just find NVG ops in a bravo to be unrealistic to about all missions. The only relevant thing I could maybe see is medevac transitions. I’m just saying. Theres a lot of airspace to practice and train elsewhere with a higher degree of safety.
