No.Can NATCA deny someone from leaving their facility for a supervisor job?
What do you mean by the facility being red? What if they weren’t in the union?No.
The National Release Policy MOU does apply to every BUE for any position in the ATO. So if you’re facility is red your selection for OS(or any position) will be denied unless a deviation is approved by the VP ATS. Currently deviations are suspended. No idea when that will change.
BUE refers to everyone covered under contract. Membership status irrelevant.What do you mean by the facility being red? What if they weren’t in the union?
Ok sorry for the dumb question but where can I find the ppt?BUE refers to everyone covered under contract. Membership status irrelevant.
Red/Green is displayed on the PPT. 85% AOB and 85% projected = Green
It’s on this site, on ksn and on natca.orgOk sorry for the dumb question but where can I find the ppt?
ThanksPriority Placement Tool
The Air Traffic Controller Resource. ATC forums dedicated to sharing information and building an online community.pointsixtyfive.com
They use projected numbers so look under projecting staffing column.When looking at the PPT what column is referencing the 85%?
AOB is column L.Thanks
Thanks for explaining. From the way it looks, it seems like there are a lot more facilities that can't release than those that can...Sounds like its going to be sometime for movement of any sort.AOB is column L.
Projected is column AA.
Both must be 85% for release.
Possible losses for is column AE. This primarily used for NCEPT but is relevant here because if it’s 0 you can’t get an MPP (usajobs) job either without a deviation.
So, If I'm in the process of taking a supervisor job, facility is not able to release normally, it's essentially a wash lol? Still not doing deviations at all. Same facility will take inhouse cpc's to supe though.. is that not a deviation?No.
What an assholeside question, if you bid a supe job, can a facrep no longer support you with questions even if you don’t get picked up? I know one that says anyone who bids a supe job gets their number deleted and no help from him. Should I get this in writing?
They only suspended deviations for very a short time. And it was more a reduction than an outright suspension. But currently they're approving a boatload. If you're selected for a sup job from ZLA you need a deviation approval.So, If I'm in the process of taking a supervisor job, facility is not able to release normally, it's essentially a wash lol? Still not doing deviations at all. Same facility will take inhouse cpc's to supe though.. is that not a deviation?
