FAA CRASHPADS Just 5m from the FAA Academy!
En Route Enroute Basics 7/13/2020
Academy Study Guides
S
SIXTY-NINE
Guest
I’m thinking the title of the virtual onboard calendar is incorrect? Showing Terminal, instead of Enroute
In basics you learn the same material but the problems on the final test are different (you have less aircraft identification problems because that's less important for enroute) so ultimately it shoudn't matter.
Solja
Just started basics in another class today. Which ways of studying seemed to help the most?
Felt like everyone had their own way of studying the material. For me, I spent 3 hours after each class re-reading what we went over that day. I wrote notes, but rarely looked at them, unless there was something that was mentioned very important to know. The instructors we had were fun folks
Cameron_KAS
They split us up in 3 classes, first two weeks of December
Thanks for the info. My class ends on the 29th of this month so I was just trying to get an idea of when our date would be. As of now are you on leave again? Also, do you still study everyday with your instructors or is it self study?
Dayday2
We are starting the next portion today. Virtual initial enroute. It's 4 hours of zoom and 4 hours self study
Cmoore21915
That’s basically what I’ve been doing too. How did the end of course test compare to the other tests?
Solja
The block tests were a good indicator on where your grade for the final test will land. Everything on the final test, was covered by our instructors. All that mattered was how much you’ve learned/retained
