- Facility
- Command Center
Air Traffic Control Specialist - Trainee
<p>Air Traffic Control Trainee</p><p>This is a developmental Air Traffic Control Specialist (ATCS) position responsible for the safe, orderly, and expeditious movement of air traffic through the nation's airspace. Developmental controllers receive a wide range of training in controlling and...
www.usajobs.gov
www.usajobs.gov
Open & closing dates
10/11/2024 to 11/04/2024
This job will close when we have received 35000 applications which may be sooner than the closing date. Learn moreSalary
$35,947 - $37,145 per year
This salary includes locality pay, which will be applicable while attending the FAA ATC Academy.
Pay scale & grade
FG 3Location
Many vacancies in the following location:- FAA - Air Traffic LocationsMany vacancies
Telework eligible
NoTravel Required
Not required - The job does not require any travel.Relocation expenses reimbursed
NoAppointment type
Temporary - Temporary NTE - 13 monthsWork schedule
Full-timeService
ExceptedPromotion potential
NAJob family (Series)
Supervisory status
NoSecurity clearance
SecretDrug test
YesFinancial disclosure
Yes - The person selected for this position may be required to file a financial disclosure statement within 30 days of entry on duty. FAA policy limits certain outside employment and financial investments in aviation-related companies. See https://www.faa.gov/jobs/workinghere/financial-disclosure-requirements.
Duties
- As a new ATCS, you will spend your first several weeks of employment in an intensive paid training program at the FAA Academy in Oklahoma City, OK. ATCS trainees will receive an hourly wage plus full benefits. The FAA also provides food, housing, and travel allowances to help offset daily cost of living while attending the FAA Academy in accordance with applicable agency policies.
- While attending academy training you will be on a temporary appointment. Academy students receive basic and initial qualification air traffic control training at the FAA Academy, which includes:
- Complete occupational indoctrination including highlights of Federal employment, familiarization with organizational structure & functions, aircraft, air traffic control system, & aviation industry, classroom instruction & workshop exercises relating to the air traffic control system.
- Individuals who do not successfully complete training at the FAA Academy and all other necessary requirements will have their employment terminated.
- Prior failure of FAA Academy training or prior declination of permanent facility placement offer after completing Academy training may constitute a basis for non-selection and/or Veterans' Preference pass over.
- Prior experience or training in air traffic control is not required. If a candidate applies for and is selected under this temporary trainee announcement, all of the employment conditions associated with this FG-3 position will apply, regardless of whether the candidate possesses the specialized experience that would have otherwise qualified them under an experienced vacancy announcement.
- If selected and hired, upon successful completion of Academy training, newly hired ATCS will be offered a permanent appointment at an FAA facility with a minimum basic salary of $45,782 plus applicable locality pay based on duty location. Applicants with prior ATCS experience will have their salary set in accordance with the ATCS Collective Bargaining Agreement, upon conversion.
- Newly hired ATCS will receive pay increases as they successfully complete the progressive phases of ATCS training at their assigned facility. It is important to note that annual salary varies greatly by facility and complexity level. ATCSs receive significant pay raises as they progress through ATCS training. On average, the salary will increase to $60,000 per year, and additional pay increases will be granted as you certify and progress at your assigned facility. Generally, most controllers are making a six-figure salary within three years. The time to reach Certified Professional Controller (CPC) or full certification and pay is approximately 2-3 years depending on the facility size, level, and complexity. Last year, the average for Certified Professional Controllers was $158,000 per year.
- The FAA has Air Traffic Control Facilities in every state as well as Puerto Rico, the U. S. Virgin Islands, and Guam. This announcement is open to applicants willing to work at any FAA Air Traffic Control Facility. Facility placements will be finalized the day following successful completion of Academy training. Declining to select a facility from the list of available facilities will result in termination of employment, as placement will be based upon the needs of the FAA.
- After successful completion of Academy training, the ATCS will enter the appropriate phase of field training as determined by the assigned facility to prepare for advancement to the Certified Professional Controller (CPC) level and must learn the skills needed for operation at higher levels of responsibility. Successful certification at assigned FAA facility is required. Failure to certify to CPC level will result in separation, demotion or reassignment.
Help
Requirements
Conditions of Employment
- US Citizenship is required.
- All applicants must pass the Air Traffic Skills Assessment (ATSA).
Qualifications
All candidates must meet ONE of the following FIVE minimum qualifications for the position, as outlined below. Additional Pool eligibilities are required based on specific Pool election. Please read this section carefully and contact Aviation Careers with any questions prior to the vacancy closing date.1. TO QUALIFY BASED ON WORK EXPERIENCE: applicants must document 1 year of full time (40 hours per week) work experience; part time will be pro-rated based on a 40-hour work week.
2. TO QUALIFY BASED UPON EDUCATION: applicants must document a full 4-year course of study leading to a bachelor's degree. An associate degree alone does not meet the minimum requirement, see #3 below. Schools must be accredited as recognized by the U.S. Department of Education and copies of the transcript official/unofficial which includes the name of the institution, semester or quarter hours earned and/or confer date at time of application.
CTI: To be eligible for Pool 1 your transcript must reflect the confer date and you must also provide the Official CTI Endorsement Letter at time of application. 2024 FALL SEMESTER GRADUATES - you must provide current transcripts (official or unofficial) and will be required to provide final transcripts reflecting degree earned and confer date prior to any offer of employment, if selected. Additionally, CTI - 2024 Fall Semester graduates will be required to provide the official endorsement letter with official transcripts, if selected. *Please note, an Official Endorsement Letter is not a personal recommendation.
3. TO QUALIFY BASED UPON THE COMBINATION OF BOTH WORK EXPERIENCE AND EDUCATION: The applicant's total qualifying experience time is converted to a percentage, then the education time is converted to a percentage. The combined percentages must equal 100%. At the undergraduate level, successfully completed education that has not led to possession of a bachelor's degree is credited based on its relationship to 120 semester hours or 180 quarter hours. Example: Candidates with an associate degree must also have some work experience to meet this combination requirement. Transcripts are required at application submission for verification purposes with exceptions for 2024 Fall Semester graduates.
4. TO QUALIFY BASED ON SPECIALIZED WORK EXPERIENCE AS AN AIR TRAFFIC CONTROL SPECIALIST: applicants qualifying based on specialized experience must provide supporting documentation that verifies this requirement has been met (e.g., FAA certificate, military certificate or training record).
5. TO QUALIFY BASED ON ALTERNATIVE REQUIREMENTS: applicants must provide supporting documentation that verifies at least one of the following alternative requirements are met:
- a. Do you hold or have held an appropriate facility rating and have actively controlled air traffic in civilian or military air traffic control terminals or centers?
- b. Do you hold or have held an FAA certificate as a dispatcher for an air carrier?
- c. Do you hold or have held an instrument flight rating?
- d. Do you hold or have held an FAA certificate as a navigator or have been fully qualified as a Navigator/Bombardier in the Armed Forces?
- e. Do you have 350 hours of flight time as a copilot or higher and hold or have held a private certificate or equivalent Armed Forces rating?
- f. Have you served as a rated Aerospace Defense Command Intercept Director?
Minimum qualifications required for all positions; additional eligibilities required based on Pool election.
APPLICANT POOLS:
POOL 1 - ELIGIBILITY:
Applicants MUST meet one of the following criteria (1, 2, OR 3) listed below, and MUST provide supporting documentation in order to be eligible for consideration in Pool 1.
1. A graduate from an institution participating in the Collegiate Training Initiative (CTI) program, and who has received from the institution an appropriate recommendation (i.e., official endorsement letter). MUST SUBMIT: (1) official/unofficial transcripts showing degree confer date AND (2) the official endorsement letter from the school. All supporting documentation must be received prior to the closing date of this vacancy. * If you are a 2024 Fall Semester graduate, you must provide a current transcript and will be required to provide the official endorsement letter and final transcript reflecting degree earned with confer date prior to any offer of employment, if selected.
2. A Veteran eligible for a Veterans Recruitment Appointment (VRA) pursuant to Section 4214 of Title 38 and can provide a Certificate of Release or Discharge from Active Duty within 120 days from the announcement closing.
3. An eligible Veteran maintaining aviation experience obtained in the course of their military experience and/or entitled to Veterans' Preference (must meet eligibility requirements in section 2108 of Title 5, United States Code) and can provide a Certificate of Release or Discharge from Active Duty within 120 days from the announcement closing.
NOTE for 2 & 3: Applicable Veterans MUST SUBMIT a DD-214 with character of service in block 24, OR written documentation (certification) from your branch of service certifying that you are expected to be discharged or released from active duty under honorable conditions no later than 120 days after the closing date this announcement. Applicants who are not within 120 days of separation will be assessed as non-preference eligibles.
Veterans Recruitment Appointment (VRA) eligible applicants:
- Disabled Veterans; or
- Veterans who served on active duty in the Armed Forces during a war, or in a campaign or expedition for which a campaign badge has been authorized; or
- Veterans who, while serving on active duty in the Armed Forces, participated in a United States military operation for which an Armed Forces Service Medal was awarded; or
- Recently separated Veterans (defined as; within the last 3 years).
- Veterans claiming eligibility on the basis of service in a campaign or expedition for which a medal was awarded must be in receipt of the campaign badge or medal. In addition to meeting the criteria above, eligible Veterans must have been separated under honorable conditions, or general discharge. Please also see section 'All Veterans' at the bottom of this vacancy announcement, for further documentation requirements for Veterans.
Pool 2 applicants are all other U.S. Citizens who do not meet the requirements for Pool 1, OR Pool 1 eligibles who elect to be considered for Pool 2.
Pool 2 applicants may not apply for Pool 1 unless they meet the eligibility requirements outlined for Pool 1.
If eligible for Pool 1, may elect consideration for Pool 2; but not both.
- Regardless of Pool election, all candidates qualifying based on education must provide official transcripts reflecting degree earned and confer date prior to prior to offer of employment, if selected for the position (this includes CTI).
- Prior graduates must provide official or unofficial transcripts at the time of application. Fall semester 2024 graduates will be required to provide current transcripts, and official copies prior to any employment offer, if selected.
Please see the Required Documents section for further information regarding supporting documentation requirements.
Education
All applicants who are using education as a qualifier must submit a copy of the official/unofficial transcripts to substantiate all credit hours earned and/or confer date prior to EOD.
Limited exceptions for 2024 Fall Semester graduates regardless of Pool election, as identified below:
- Applicants must document a full 4-year course of study leading to a bachelor's degree. Schools must be accredited by an accrediting institution recognized by the U.S. Department of Education and copies of the transcript official/unofficial which includes the name of the institution, semester or quarter hours earned and/or confer date must be provided at time of application.
- CTI graduates - to be eligible for Pool 1 your transcript must reflect the confer date and you must also provide the *Official CTI Endorsement Letter at time of application.
- 2024 FALL SEMESTER GRADUATES - you must provide current transcripts (official or unofficial) and will be required to provide final transcripts reflecting degree earned and confer date prior to any offer of employment, if selected. Additionally, CTI - 2024 Fall Semester graduates will be required to provide the official endorsement letter with official transcripts, if selected. *Please note, an Official Endorsement Letter is not a personal recommendation. This letter should be on official CTI school letter head, signed by the designated CTI point of contact, and certify/endorse that all CTI program requirements have been met (or would have been met/effective as of 12/31/13).
