1,300 replies · 354,667 views · Page 47 of 66
  1. nab #921
    Mike_Lima said:
    Well AUS doesn’t even have the intersecting runway multiplier nor a bravo, so it’s definitely harder for them to hit and sustain the number.
    The Bravo multiplier is complete BS, tell me why having a class B equates to 25% more complexity than dodging VFRS in unprotected class C airspace. AUS doesn’t get 15% multiplier for having a crossing runway. BNA and DAB never use their crossing runway like most facilities excluding a tiny few. Why do they get 15% more TCI? Appendix A is flawed. AUS is the only up/down level 9,10,11,12 who doesn’t have a crossing runway or class B airspace. That’s %15-%40 percent less multiplier than the rest.
  2. GulfBravoPapa #922
    Did I miss BNA getting a Bravo?
  3. nab #923
    BNA has the extended class C and they have 4 runways, 1 that crosses that rarely gets used. AUS works more traffic but blows thru management every 6 months and doesn’t get shit done. AUS has 2 parallels with more traffic but is 15% “less complex” than BNA because there’s no crossing runway.
  4. Soul_Controller #924
    The one facility type that shouldn't even be remotely complaining about TCI are updowns. A 9 updown is usually slower in the tower than a 9 tower only and slower on radar than a 9 tracon.
  5. Mike_Lima #925
    I wasn’t trying to argue against the fact they shouldn’t be a 10, I think the formula how it currently is, definitely hurt facilities like BNA and AUS that’s were and are pushing for upgrades.
  6. nab #926
    Disagree, look at MSY who has Class B and a crossing runway compared to AUS class C no crossing runway. AUS does over double the ops of MSY yet both level 9’s. TCI is fucked.
  7. SquawkHijack #927
    ajmezz said:
    Meanwhile AUS is doing more than BNA and doesn't get an upgrade. Kinda odd.
    AUS is pushing tin, I still talk to a guy from my facility that just started as a support specialist there and says it’s been bumpin!
    GoGators said:
    I just want to know how SAN gets more staffing than my facility with less traffic, 35% less gates, having ramp control while GC at my facility has to deal with push backs.
    We obviously failed at inflating positions needed.
    Oh and supposedly no departures from 2330-0630 due to noise abatement according to airnav? Wtf.
    Ramp control additions have to do with the amount of gates per single constructed terminal. For example, if you have two separate terminals at an airport with 25 gates per, you don’t get ramp control, if that same airport builds a single terminal with 30+ gates (doesn’t have to be the only terminal there) then ramp control is required. Like all things with the FAA, it boils down to numbers…
  8. J8ke #928
    That is not true unless my facility is grandfathered in.
  9. SquawkHijack #929
    You are grandfathered in unless any new construction is built, this is only applicable to airport terminals built after a certain date which I don’t exactly know.
  10. Soul_Controller #930
    Those are both updowns. My point is that you get to be slower in the tower than a tower only like DCA and slower in the tracon than a stand alone tracon like Memphis. But you all get the same facility level. Plus TCI exists because volume is just part of it. I'd rather work AUS than SAT whether or not there is more planes at AUS.
  11. Wizard #931
    I don’t think you understand how much it takes to get to a level 10 with a Charlie.
  12. Soul_Controller #932
    My point is that you don't really deserve to even be nines if you want to make it all about pushing tin. Split AUS and you don't get two nines
  13. Wizard #933
  14. Soul_Controller #934
    So the radar MIGHT be a nine (it's no where near a 10). The tower definitely isn't a nine.
    There are issues with TCI. Capping at 12 is bullshit on the high end. And vfr towers get penalized too much at the low end. But if every updown split, a lot of yall would be making a lot less money.
  15. GulfCharlie #935
  16. J8ke #936
    They added on to one of our terminals in 2020/2021. Total of 9 gates for terminal 1 and 50 gates for terminal 2. It's moot because ramp control would never work at our airport anyway but I had never heard of the rule you claimed before.
    TCI is very messed up. AUS should definitely be a 10.
    I did a brief sampling of many 8/9/10 up downs and most had at least one part of the facility that standalone, would be enough to be the same traffic count level. If you're asking a controller to be certified in two different types of facilities they deserve some type of extra pay.
    Instead take a look at JAX next time you have access to the TCIP site. They are a lvl 9 and their tracon is very busy but they have a relatively slow tower. They would actually be %wise closer to a lvl 10 if they were tracon only. Like the current TCI formula actually punishes them for having a tower.
  17. Homsar #937
    boots forgot to include another example of why TCI is messed up. FFZ running busier traffic but MYF still getting the 9 over them, likely only because of the crossing runway.IMG_8588.jpeg
  18. EightTwoSierra #938
    For you facilities that have upgraded, was management on the case to get the raise? Or was it worked on from outside the facility? We are trending towards level 8 and should be above the 8 line in a few months, but our ATM is almost retired and has zero interest in lifting a finger to even start the process.. He won’t even make a phone call to figure out what needs to be done.
  19. SquawkHijack #939
    It’s definitely a thing but I’m wondering if you guys maybe got a waiver or deviation since it wouldn’t be beneficial to airport ops as you say.
  20. Termine #940
    FAA: The 804s will continue until morale improves.
    Speaking of facility levels, I saw Rich speak recently and one thing he mentioned was that he thinks there are too many levels, which I'm kind of on board with. Though I wonder if the stakes would be even higher if you consolidated from nine different levels down to four or five... you'd still be having these same arguments on the edges. The solution to that would be to make the pay difference pretty minimal between one level and the next, but if you did that you'd have the high-level controllers complaining about how hard they work compared to places like APC/DAY/POU for "only" so much more per year.
    Basically controllers are our own worst enemies.
