NEST May 2020
Stinger
Moderator
The May NEST has now been canceled. It was originally scheduled for May 7th, but has now been postponed until June 9th. The deadline for package upload is May 28th.
Luawinposition
ROC Rochester Tower
Thanks for the update, I didn’t know the new date. Think it will actually happen? My training was terminated at a level 6 up/down. Assuming they keep me on, how does the list process work?
FightingIrish2012
No crystal balls but these circumstances could help you. Next panel is set for June, if your already in the hopper you might be at the top of the list. Plus with the academy shut down no new academy grads will take up slots at the very low level facilities you could be reassigned too.
Luawinposition
ROC Rochester Tower
Or we get screwed and terminated because staffing is too high for current/projected traffic. It would be an easy way to get rid of some dead weight. 🤪
odotsal
I90 Houston Tracon
I'm noob when it comes to this stuff. Does this mean there will be an NCEPT panel too or only NEST? Asking for a friend.
FightingIrish2012
Maybe you are right, could go either way lol. At least with these delays nobody who has their training suspended will do so while under the one year probation period.
Move78
This won't happen. Due to the training hold national staffing will fall backwards again like it did during the shutdown and the dismal traffic projections are not permanent. Expect to get a list of a bunch of 5s that are below 100 projected on the ppt. Unless you didn't get any control position certs. Then termination is much more possible.
Staffing is light years away from being too high.
