GulfBravoPapa
⭐SuperStar
If it wants dates for jobs put the dates in the comment section. People have been eliminated for not doing it. Don't give them that reason.
Not necessary. Fill out the USAJobs resume builder completely and there will be no issues.If it wants dates for jobs put the dates in the comment section. People have been eliminated for not doing it. Don't give them that reason.
ATC Prep. I swear it helped me get a job. The week before my AT-SA I spent an hour on it each night. It isn't identical but gets you used to what you need to do.What is the name of that AT-SA prep software that people used for the last bid? (I think it was an iPad app...?)
People haven’t been eliminated for it. They say to use the resume builder. So use it.If it wants dates for jobs put the dates in the comment section. People have been eliminated for not doing it. Don't give them that reason.
So this website? Just wanna make sure it's the right thing... Do you recommend the PC version or the iPad version? (I imagine PC may be better since you have a real keyboard, etc)ATC Prep. I swear it helped me get a job. The week before my AT-SA I spent an hour on it each night. It isn't identical but gets you used to what you need to do.
I second this, I used it and I got a TOL, could be coincidence, but it was super helpful to me. Just adjust out the AT-SAT sections. It'll help you focus on the main four that you will be taking.That's the one! I used it and got best qualified. I would recommend PC because getting used to using a keyboard and num pad to do the tests is important, in my opinion.
I haven't bought it yet, so this may be clear if I do, but what are the four sections that relate to the AT-SA?I second this, I used it and I got a TOL, could be coincidence, but it was super helpful to me. Just adjust out the AT-SAT sections. It'll help you focus on the main four that you will be taking.
Yes. Definitely do it on a PC as your AT-SA will be on a comp with keyboard.So this website? Just wanna make sure it's the right thing... Do you recommend the PC version or the iPad version? (I imagine PC may be better since you have a real keyboard, etc)
I can verify that guy is a idiot. It is true that a credit check is part of the background check and is the number reason people are DQ’ed, but there is a website that you can look at the reasons why people fail that check and whenever it’s for credit it’s for extreme example. Being 100K or more in debt and behind of most of your payments most of the time. So a case similar to that will certainly DQ you, but you don’t have to have “great” credit, and the comment that there is a set credit score that if it drops under you are fired for once you are controlling is nuts.FYI, saw this on the FAA’s IG post regarding the June 14th bid. Can anyone verify this?View attachment 2564
It doesn’t matter how much debt you have. It really only matters if you are in default. If you own a house your probably have hundreds of thousands in debt.I can verify that guy is a idiot. It is true that a credit check is part of the background check and is the number reason people are DQ’ed, but there is a website that you can look at the reasons why people fail that check and whenever it’s for credit it’s for extreme example. Being 100K or more in debt and behind of most of your payments most of the time. So a case similar to that will certainly DQ you, but you don’t have to have “great” credit, and the comment that there is a set credit score that if it drops under you are fired for once you are controlling is nuts.
