Hiring Bid FAA-FAA-24-PUB NOT-87164 (Prior Exp Rolling Bid)
Oh I see what you're getting at. Still the same process. Apply direct to facility. ATO decides offer, may/may not be facility you applied to.
I thought the new reinstatement got rid of this. Thought it was you apply pretty much through HR/ATO now and they give you a list, kind of like a prior exp bid.
Is there any type of preference based on facilities? Is there a region I can choose or top facility locations? Or is the list just complete needs of the FAA take it or leave it?
Apparently security is backlogged,
No one knows yet if this bid will be different than previous, in the past the list have been facilities all over based on your experience and then wherever the faa wants you
I talked to one of the training guys from NATCA the other day, he said it should be similar, with lists and what not. But the union and HR will both look at your resume to see what level of facilities will be on it.
Are they not going to go by the rubric/current SOP? Would that mean NATCA would or could push for certain people to be sent to higher or lower levels than the SOP?
Well the faa did not ask what region, state, facility, etc they just gave out a list
