Mr.Tickles
Looking for some clarification here in regards to uncontrolled airports due to conflicting opinions in my area. Most are of the opinion that uncontrolled airports are strictly one in and one out. As in once an approach clearance has been given no departures can get out on an IFR release barring a VFR climb.
I’ve not been able to find or been directed to where in the .65 this is specifically mentioned as of yet.
In 6-3-1(Nonradar) it seems like you’d still be able to release departures after giving an approach clearance as long as they comply with the 5 or 3 minute rule for the arrivals estimated time at the airport. I’ve been told by several people that this only applies to towered airports.
Here are the two rules.
D.When takeoff direction differs by at least 45 degrees from the reciprocal of the final approach course, the departing aircraft takes off 3 minutes before the arriving aircraft is estimated at the airport.
E. When takeoff direction is other than in subparagraph d, the departing aircraft takes off so that it is established on a course diverging by at least 45 degrees from the reciprocal of the final approach course 5 minutes before the arriving aircraft is estimated at the airport or before it starts procedure turn.
Do these rules only apply to a towered airport?
Anyone have any more specific references or knowledge that support one or the other?
