Dontbotherme
Much needed change, but they should be glad it stops at FY2014 as the numbers here would be even lower after being forced to receive people from the NCEPT and VRAs.
It's probably due to a small sample size and that sample size being unsuccessful though their traditional checkout rate could be much higher. Hypothetical examples: Only 8 people transfer/new hires at P80 (staffing relatively good) and 4 make it=50%. Say 120 transfer/new hires at A80 and 60 make it= 50%.Does P80 really have a lower checkout rate than A80 and C90?
I'm hoping this new checkout percentage puts A80 up higher on priority this time. Being that low but eligible to select so many is ridiculous. Put A80 in the top 5 along with the other two terribly staffed large TRACONs.It's probably due to a small sample size and that sample size being unsuccessful though their traditional checkout rate could be much higher. Hypothetical examples: Only 8 people transfer/new hires at P80 (staffing relatively good) and 4 make it=50%. Say 120 transfer/new hires at A80 and 60 make it= 50%.
My current list would be something like:I'm hoping this new checkout percentage puts A80 up higher on priority this time. Being that low but eligible to select so many is ridiculous. Put A80 in the top 5 along with the other two terribly staffed large TRACONs.
Hell yea I like that list lolMy current list would be something like:
N90
A80
C90
ZNY
I'm sure I'm giving both sides too much credit. I can only assume the real motivation with this new process was to make sure they don't rob Peter to pay Paul. They're trying to prop the staffing up nationally all together. There's obviously an enormous number of serious unintended consequences that we can see now that's it's been implemented.Lol!!!! This is the most poorly executed "goal" I could think of. Even it was shared, the only thing that's being looked at is the movement itself. It's all a numbers game with no regard to merit, seniority, etc.
If they limit movement how are they going to up the numbers at 8-12s? And the numbers getting increased at 8-12s is what saves the agency millions of dollars in OT.increased movement is absolutely not a goal. the goal is to limit movement so they can up the numbers.
New hiresI'm sure I'm giving both sides too much credit. I can only assume the real motivation with this new process was to make sure they don't rob Peter to pay Paul. They're trying to prop the staffing up nationally all together. There's obviously an enormous number of serious unintended consequences that we can see now that's it's been implemented.
They've slowed down sending new hires to higher levels dramatically. It was really bad last 2 summersNew hires
The faults were clear and predictable from the beginning.There's obviously an enormous number of serious unintended consequences that we can see now that's it's been implemented.
And what constitutes a while only he knows... could be 3 years, could be 10.The faults were clear and predictable from the beginning.
Andrew LeBovidge talking about the high level facilities: "They're just going to have to suffer for a while."
Rumor has it that P80 is extremely complex. Lots of MVAs. Crazy wind shifts on final regularly. Etc.
P80 has had two or three people straight quit the agency while in training the last couple years lol. They haven't been getting a lot of inbounds but the training program and airspace can be complicated. I have also heard bad things about the work environment, disgruntled workforce etc.
I have faith but my facility is in a good place to release 2 or 3 next panelThere are gonna be some really hurting people after this reshuffle of the numbers in July.
We were basically guaranteed to be cat 2 in sept but the PPT will be upended drastically next week and now we'll be miles away from being able to release. This is without any actual staffing changes, it's solely because they're doing the math different. Are you sure your proj is going to increase at a larger rate than the new natl avg? It'll be a big hurdle.I have faith but my facility is in a good place to release 2 or 3 next panel
our training time went from 2 to 1.4 and our success rate went from 68.7 to 83... our projected is still going to be over 100% because we have 8,000 developmentals.We were basically guaranteed to be cat 2 in sept but the PPT will be upended drastically next week and now we'll be miles away from being able to release. This is without any actual staffing changes, it's solely because they're doing the math different. Are you sure your proj is going to increase at a larger rate than the new natl avg? It'll be a big hurdle.
