GulfBravoPapa
⭐SuperStar
Apologies if this has been answered before. I did search this thread, somewhat.
1.) Prior CPC applicant to this OTS bid. Do I have to go through AT basics at the Academy?
2.) Do all OTS applicants go through the tower track? If not, when do you know if you'll be going through RTF or En Route?
3.) Being an OTS bid, are the facilities offered at the end of the academy generally lower level facilities?
1. You have the option to skip basics
2. You will be given either an enroute or terminal TOL. This is always subject to changed based on the needs OF THE AGENCY, not you. You would attend the classes as necessary for that route.
3. All facilities offered to academy graduates are level seven and below... VERY rarely there is a level eight such as OKC. Approximately two weeks before your class concludes you will be given a tentative list for your class. Depending upon how many people pass your class, there will be that many facilities to select from (there may be multiple slots for one facility). Best picks first, worst but still passing gets what is left.
