Alright so I received a TOL and I think now would be a good time to ask some questions that I've had pertaining to the job. I'd really appreciate it if someone could fill me in on some of this.
-- From my understanding TRACON deals with ascending/descending, the go between from enroute to terminal. How does one eventually get a TRACON position? Do they do the terminal route at the academy? Do they have to get good at terminal and then do additional training for TRACON?
Terminal RADAR Approach Control (TRACON) is Terminal and you CAN get assigned to a TRACON out of the academy, most likely an Up/Down facility which is a Tower and an Approach Control in one facility. OR you if you applied to N90 specific bids then you can possibly go there, I don't think any academy guys get sent to TRACONs like S56/S46/U90/Y90. There is RTF, TSEW, and TETRA there is probably info on these courses somewhere on this forum.
--An up/down facility is one that has both tower (terminal) and TRACON working in close proximity to each other?
--Hypothetically say you pass terminal at the academy and get assigned to a level 4-7 tower. You then become certified there and do well. I assume you then are able to move up to a level 8-10 tower?
It is possible, but it is up to the manning at your facility and if the place you want to transfer to can pick up people.
--D side/R side. Do these terms only pertain to center/enroute controllers?
R-Side = guy who is actually talking to airplanes
D-Side = guy who helps the R-Side by doing coordination for them and other assist functions.
--I see people at the academy referring to non-radar and radar problems. What's the basic gist of these? Are these only related to enroute?
I'm not sure if you want a basic explanation of RADAR vs non-RADAR or info about the problems at the academy, but it can apply to enroute and terminal.
--Location is fairly important to me but I'm not going to bitch about it if it doesn't work out in my favor. How often are people able to transfer to their preferred location? Only if that preferred location has open availability I presume?
Any info at all on this stuff will help. Thanks.
