Robert_Boucher
Well ain't that some sh!t.
What you all don't know, and I just found out from a former FacRep...
If a facility can pick up 5, but only selects 3... The other 2 will most likely be hardships. These are done at the same time but not told to anyone. Our former FacRep was tired of doing all the work to pick up one or two to get none, but get two hardships on the backside. So it's all done at the same time.
I’m not sure about that. The methods of staffing a facility (NCEPT, new hire onboarding, NEST, etc) run independent of each other, and are based on locked-in PPT numbers for that given time period. That’s why VGT got enough people to be 140% staffed last year, as they were at ~70% staffing and thus each method of facility staffing treated them as a priority. Since they don’t communicate with each other, each method staffed them to 100% independently, which is why they ended up so much over 100% in the end.
Truth be told, if what you say IS true, it would be a better explanation than “we don’t want to staff a facility over an arbitrary, non-transparent number because of a training backlog.” We should see those hardships reflected on the next PPT if that’s indeed what happened, but then the question arises as to why they’re not using locked-in “possible gains” numbers on the NCEPT Priority list, nor locked-in PPT numbers.
There should be documentation for what you describe, else it’s running against the SOP.
So the priority list says MLU is not CAT 1 or CAT 2 and 0 people can be picked up from that facility. But on the NCEPT list someone from MLU was picked up to HCF and it says MLU was CAT 2. I don't get it
There should be documentation describing the fact that the NEST, PrevExp, and hardships all effect the staffing of facilities in a consistent manner?
There can be staffing corrections after the staffing worksheets is published official. People will see it and say "that is not right" and often fixes are made that are not published. They are however accounted for in the NCEPT selection. MLU is not the only facility that had 0 to release and let 1 go.
I think this just hammers home the fact that no one really has any clue how this process is suppose to work and that your request to go somewhere is a lottery pick. I dont get why it's that way but it is what it is. I think that it should just be a usajobs posting or something when facilities are picking up and then you apply like it's a new job request. Then at least you can know what a certain facility is looking for (i.e. type of certifications, number of years of CPC experience, etc.) At least then it's a little less clandestine operation that what the NCEPT process seems to be.
What about a facility that can gain 1-2. ATM sent in their ranking and that facility gained none. Even though I was told 9 people sent in ERR to that facility. Just seems odd that it was skipped over.
I hadn't heard of unpublished PPTs being used as a basis for NCEPT panels before. That's pretty shady if true.
The list is not "locked in" it is a very dynamic list which changes consistently. If the list is published 2 weeks before the panel doesnt mean it's solid. I can't find anywhere in the SOP where it says the list can't be affected by other placements as well as it's a part of the DL tool to factor projected AOB and staffing levels.
Has anyone heard an instance of someone being "unselected?"
