It was in a briefing because of a situation that needed looked at. I’ll try to get an answer from the QCG. I use fixes for overflights all the time esp when an aircraft is on an airway. If I know the radial the aircraft is on I’ll just use 20 degrees for a little extra room but it helps me climb thru or descend thru without gaining 3 miles or stopping someone at an intermediate altitude. The way it was briefed was that for initial separation ( in this case off the runway ) headings must be used. And to me that contradicts the word “courses” in the .65
If you have NIDS, ask your NIDS person to ask their tech support contact. Its not an official app or anything... a controller made it and lets them use it.Any chance someone could provide a link to FIXFINDER. Been trying to get that here for years. I also find it very odd at the assessment from the QCG.
I've always just used a combination of Airnav.com and skyvector.com to get headings to other airports/vors/fixes.Any chance someone could provide a link to FIXFINDER. Been trying to get that here for years. I also find it very odd at the assessment from the QCG.
I agree with MJ that we need more info here. I mean if you issue a 280 heading to 1 and a direct XXX VOR which is a 300 to the 2nd and the 280 tracks a 290 because of the wind and the direct XXX VOR tracks a 300 because he's direct then yeah you're gonna have a loss there.I agree with courses but also believe when in doubt use headings. Had a briefing here from a situation ( I know this isn’t on the topic of a visual approach as discussed above but still divergence related ) the eastern region quality control group says that use of a fix for initial separation does not qualify for divergence. So if runway heading is 280 and XXX VOR is 300, the first aircraft must be given a hard heading of 15 or more vs. proceed direct XXX. Idk if that helps just found it interesting that the East QCG determined that.
No that’s a good explanation. It’s exactly what I would have expected. Them saying the fix isn’t good for divergence meant it can’t be used to satisfy the 15° rule without actually having 15°, which is but there’s always someone...I inquired about the situation yesterday got a response from the FAA today unfortunately it was told to me and was not giving in writing. The response of “no fix for initial separation” was used for the specific situation that had happened here, which was first aircraft (C182) direct VOR (HDG 26 and second aircraft (CRJ9) Rwy HDG 243. It didn’t work mostly because of how the skyline tracked. What I didn’t like was the blanket statement “no fix for initial separation.” So that was what was questioned. They responded with, if you are going to use a fix or two fixes for divergence you must be able to prove that the courses will diverge. Therefore if you recognize that one or the other are not tracking a heading that will be at least 15 degrees then you need another form of separation or you need to get 15 another way. (Hard heading). I’m not overly satisfied with the response but I think it echoes what most of us feel that you need 15 degrees. However you get it they don’t care but you need it and need to prove you had it. The question started from the Briefing not specifically saying that this was only an assessment of the situation and not how they feel about divergence as a whole. Sorry to be long winded and if it’s not satisfactory in the response.
I think the issue here is these situations didn't actually create 15 degrees.See that's crazy to me ... If you can hypothetically stick a 15 degree protractor on the scope and show you've got 15 degrees, who gives a damn? Why is so much emphasis on headings when both the book and FAA say it's about their track not the heading... We all know there are days when 15 degrees doesn't buy you 15 degrees...
But they'll let you have less than 15 degrees actual track if you issue a 300 and a 315. But a 300 and a direct that's supposed to be 315 doesn't count, if you don't get 15 degrees track, because headings and direct to fix are not the same.I think the issue here is these situations didn't actually create 15 degrees.
Maybe I'm wrong thenSee that's funny bc we've had people fry over 15 degree hard headings not buying true 15 and them pinning it on them needing 15 degrees track even w hard headings... Which by your explanation(s) is incorrect and it shouldn't have been an issue... Which I'm always on Team Less Rules/More Ambiguity... I guess I just always want 15 track, regardless of heading... Much like a 30 degree intercept for ils... Doesn't matter heading, just need 30 or less track...
Looking forward to being in your same position in March lolIm so glad I don't work at a facility that has the time to argue over this stuff
