Situation: management says we must include “simultaneous” visuals on ATIS but when running “dependent” parallel ILS we don’t have to advertise “simultaneous” ILS.
We run dependent parallel ILS only with RWY more than 4300ft apart.
My reading of the 7110.65 was either you have to put “Simultaneous” for ILS if you are say the 7110 requires ATIS to say “simultaneous” for visuals. The wording is nearly the same. Neither says the word simultaneous but you can interpret their intent is to advise pilots of the closer proximity of other aircraft on final.
The only thing that says simultaneous is independent IFR approaches.
Visual Approaches to Multiple RWY: 7-4-4(a) “All aircraft must be informed that approaches are being conducted to parallel, intersecting, or converging RWY. This may be accomplished through use of the ATIS.”
Dependent ILS: 5-9-6 (b)(4) “Aircraft are informed that approaches to both RWY are in use. This information may be provided through the ATIS.”
