Typically they will send out a TOL to the next people on the list once those people are disqualified but they will not give out more TOL expecting people to be DQWouldnt they have to select more people than they intend to hire to account for those who will fail during the medical, security, and other test on down the line?
So critique my thinking here folks. Full disclaimer, I know this has room for error/ variables:
4968 qualified candidates took the ATSA. Let’s assume 75% passed(I’d assume less actually did, but for the sake of the exercise we will go high). That’s 3726.
Hiring goal is 1431. Assuming there are no other outside bids(I know there are but don’t have even an approximate number of how many), you would need to be in the top 38%(1431/3726) of scoring to receive an offer.
What all am I not accounting for that would decrease that number, and by how much?
How about just worry about getting a TOL first.How long do you think it would take to get certified Tower go back to the academy for TRACON and get certified for that? I would like to end up back in my home state where there is no En Route, so this is why I'm curious about TRACON.
And good luck getting a facility that is in your home state. You will most likely go to where the FAA needs you. Just like the military. You’ll choose based off a list of facilities of where the FAA needs bodies the most at that particular time. If I were you, I’d be open to whatever you can get.How long do you think it would take to get certified Tower go back to the academy for TRACON and get certified for that? I would like to end up back in my home state where there is no En Route, so this is why I'm curious about TRACON.
I am 100% open and completely understand the process but I also know there is a program for transferring. I'm the type of person that likes to know all my options and possibilities and how things work. For instance, if I do get tower I will pick (if possible) an up/down location no matter where that is in the country. This way I have more options if I wish to transfer later. I did not even consider this before asking questions. I know I will probably end up Enroute anyway. The upside is the pay, the downside is locations are more limited, but I'm already compiling my list of top choices for Enroute.
We are probably in the same boat. I see no harm in having an idea in your head of how you'd like everything to pan out, as long as you are aware of just how much is out of your hands. I'm the same way, I have a list of places I would love to be assigned, but realize that the FAA doesn't give two craps what I want. Best of luck to youI am 100% open and completely understand the process but I also know there is a program for transferring. I'm the type of person that likes to know all my options and possibilities and how things work. For instance, if I do get tower I will pick (if possible) an up/down location no matter where that is in the country. This way I have more options if I wish to transfer later. I did not even consider this before asking questions. I know I will probably end up Enroute anyway. The upside is the pay, the downside is locations are more limited, but I'm already compiling my list of top choices for Enroute.
Enroute is the way to go if you dont mind living in one of the (insert number or center facilities here) locations. If you dont enjoy any of those locations Terminal is probably the route. Theres literally hundreds of terminal facilities. Plus plenty that make the same if not more money than enroute. Some people care more about location than pay and you cant blame emYou’re worried about Step 100 when you’ve been checked out, complaining about your spot on the break board and where you want to transfer to. There is nothing you can do to better your of where you will eventually end up.
You need to be focused on getting a TOL and passing so you can get AG pay first.
And for the record, en route is the way to go. I see tower people coming in with more seniority but have been making a lot less and even when they do checkout, I’ll still be making $20k more than them per year for the rest of our careers. That adds up after 20 years.
Am I the only one freaked out about the MMPI and physical? I’m petrified of getting Tier 2’ed or failing the physical.
