GulfBravoPapa
⭐SuperStar
Just read all the directions and utilize the practice tests available to you prior to completing the actual test sections.
Is there any indication of when each scenario is nearing completion? How do you know there won't be more objects entering the screen?
Can anyone explain what this means and which tests it applies to? How could there be no penalty for wrong answers?
^ Good stuff. For the near impossible head math questions, remember to round to get you in the ballpark.
Ex. 2467.75 x 552.34 turns into...
2,500*500 =
250,000*5 =
1,250,000
The answer will be above 1,250,000.
Because math is used daily in our career to calculate distances, over takes, speeds, spacing, angles, etcIs anyone able to explain why there are math questions on the test? I'm not horrible at math, but at the same time it is definitely not my strongest suit.
Tons of crazy equations to remember or is it pretty simple just with strange numbers?Because math is used daily in our career to calculate distances, over takes, speeds, spacing, angles, etc
So they got back to me and sent me a copy of the software. I plan on making a couple short videos with it, but my initial impressions are pretty good. It does have the AT-SAT material in it, but it’s in a separate section. Ignore that section entirely. It worked well and tracks your scores and progression. I can see it being helpful in preparing. If nothing else, it helps build muscle memory, develop techniques that work for you without anything being at stake, and eliminate some anxiety of going into the test blind.No personal experience, but parts of it look ok. Much of it is outdated though, so that gives me some pause. I'm going to reach out to the developers.
The collision test is directly applicable to the job. I feel like this is a really good aptitude test for radar.Is anyone able to explain why there are math questions on the test? I'm not horrible at math, but at the same time it is definitely not my strongest suit.
If this is a question in regards to the ATSA I don't know. As far as actual work... Not really crazy equations. And a lot of what math you'll need to know depends on what you end up working. Some facilities have all the technology that does most of the work for you on final (ATPA) others you will have to manually calculate overtake speeds in your head to determine if the sequence will work.Tons of crazy equations to remember or is it pretty simple just with strange numbers?
Sweet! I'll tell a few people I know that the program has been updated and will help with their ATSA prep.So they got back to me and sent me a copy of the software. I plan on making a couple short videos with it, but my initial impressions are pretty good. It does have the AT-SAT material in it, but it’s in a separate section. Ignore that section entirely. It worked well and tracks your scores and progression. I can see it being helpful in preparing. If nothing else, it helps build muscle memory, develop techniques that work for you without anything being at stake, and eliminate some anxiety of going into the test blind.
So I went ahead and bought the ATCPrep software and have been doing some practice tests, specifically the in-air pong style collision with math at the bottom. It would be nice to know if it's in our best interest to guess on ones we don't know versus just not answering. There were some also I completely missed because I was more focused on the collisions. I'm getting 90%+ on the collision part and 70ish% on the math so I'm not sure how important it is to bring up my math scores as opposed to keeping priorities and focusing on the collisions. I know though most likely no one really knows the answer to this haha.
I passed the AT-SA and mostly ignored the math after a certain point. When a radar scenario was up and active I would prioritize removing conflicts. Most people I know that passed did the same. I honestly think it's there to distract and overwhelm most test takers.
I have to disagree with you on that one. I think it's meant to text your multi-tasking skills. I wouldn't entirely disregard the math. I answered as many I possibly could, but separation was primary.
2,500*500 =
250,000*5 =
1,250,000
