Chickadee1514
For pool 2 they did NOT refer everyone who scored best qualified, and it looks like they referred VERY few of the well qualified. If you didn't score best qualified you should probably retake it.
I believe some people are told that they were not referred because they were not selected by the particular algorithm used by FAA. If you go onto the June hiring thread, there seems to be a number of people who are from the Pool 2 - Best Qualified that too did not get referred, so I believe no one knows how said algorithm works in selecting candidates.I got my status updated to Not Referred, though it says my AT-SA placed me in the Well Qualified category. Just confirming, does this mean I passed the test, but got denied for other reasons?
I was thinking the same thing. I'm P2-BQ Referred, but I'm sure I bombed or did somewhat mediocre for both the simulation part and the logic section of the test. Also previous candidates have given personal accounts where they have been referred in past bids but felt the same as I about not doing well in either portion. However I feel I aced everything else, while being quick about it, and did well in choosing ideal ATC candidate traits in the personality test. So from that logic, my reasoning is leaning towards how ideal you choose for the personality test or how QUICK AND ACCURATE you were able to complete the first section with the memory game of the number differences and variables being vital. But then again your entire test taking time could be a contributive factor too. But then again everything I've just said could be entirely irrelevant and maybe the FAA just draws names/numbers out of a hat.The algorithm is definitely interesting. Especially when you got some WQ that got referred and some BQ that did not. Meanwhile I’m P1Q and got referred. I always thought the 10% rule meant they had to hire within 10% of each pool but also go down the line of BQ, WQ, then Q only if needed. Maybe they weight it based on different portions of the test? Hmmm.
Who knows at this point 😂 maybe they base it off our resumes and the test doesn’t mean anything at all but it’s a formality.I was thinking the same thing. I'm P2-BQ Referred, but I'm sure I bombed or did somewhat mediocre for both the simulation part and the logic section of the test. Also previous candidates have given personal accounts where they have been referred in past bids but felt the same as I about not doing well in either portion. However I feel I aced everything else, while being quick about it, and did well in choosing ideal ATC candidate traits in the personality test. So from that logic, my reasoning is leaning towards how ideal you choose for the personality test or how QUICK AND ACCURATE you were able to complete the first section with the memory game of the number differences and variables being vital. But then again your entire test taking time could be a contributive factor too. But then again everything I've just said could be entirely irrelevant and maybe the FAA just draws names/numbers out of a hat.
If only. But they have their own system in place to attempt and acquire the best and the most ideal candidates for the job. And so far it seems they've been doing so effectively. Can't disregard that aspect of their process.Who knows at this point 😂 maybe they base it off our resumes and the test doesn’t mean anything at all but it’s a formality.
True dat, future ATCerIf only. But they have their own system in place to attempt and acquire the best and the most ideal candidates for the job. And so far it seems they've been doing so effectively. Can't disregard that aspect of their process.
Best of luck to you sir. Have a good one.True dat, future ATCer
Any advice on how to study for the ATSAT?Yes, hard to imagine anyone got through the math and separation without separation issues. I had a similar issue on the AT-SAT but still scored a 100
Thinking about "How many I need to get right/wrong to score a BQ" is the wrong mindset. Just perform to 100% of your abilities.
And always, just keep moving on and try not to dwell on anything. You answered the question and you can't go back. Just focus on the present.
yesI see the post is from 2016 is it still relevant now in 2020?
I took the test this week. The hardest part, by far, is the simulation and math part. I think my testing facility has defective computers because the simulation would load and multiple "planes" had already collided. As for the multiplication at the bottom of the screen, well, mine was there for half of a second at most. And there were 2 instances where the options for answers didn't appear at all. Good luck.
did you try the contact form ATCPrep.com - Preparation Suite for Air Traffic Controller Selection (ATSA and AT-SAT)I can't get ATC Prep to load up on my computer. Never had this problem the first time. I tried to Mr. Robot my way into the problem but still nothing. Pretty sure their support team doesn't exist anymore because when I sent an email it immediately got kicked back.
Had the same problem, contacted support and they said it was either windows defender or AVG kicking the program out. I uninstalled AVG and sure enough ATCPrep worked. Hope this helps.I can't get ATC Prep to load up on my computer. Never had this problem the first time. I tried to Mr. Robot my way into the problem but still nothing. Pretty sure their support team doesn't exist anymore because when I sent an email it immediately got kicked back.
