Listen, I understand the desire to want to learn EVERYTHING. I was the same way when I went through, but you have to understand something. The academy is about learning concepts. Not memorizing everything. If I explained to you the concepts of how to drive a car, do you think when push came to shove you could drive the car with the concepts I taught you? That’s exactly what the academy is like. You’re presented with learning opportunities that will help you with the exams, you will learn the concepts and put them in to practice.
Honestly what will help you the most is taking a break. Breathe, meditate, do whatever it is that you need to do to calm down and relax. The academy is certainly stressful but it’s also only as stressful as you make it. If you can get a little ice in your veins you’ll be fine. Just relax and understand that you’re not going to know EVERYTHING but if you Apple common sense and apply the concepts you learn you’ll be fine. Just take a breather homie.
