yup
5-2-15. Ensure that Mode C altitude readouts are valid after ... initial track start ... except as follows: c. Consider an altitude readout valid when: 2. You receive a continuous readout from an aircraft on the airport and the readout varies by less than 300 feet from the field elevation.
So the ASDE shows the aircraft at field elevation. Now I know that the aircraft's Mode C readout is valid on the ASDE display. Great.
Can that validity transfer to a STARS target, or does the continuous on-airport readout have to be shown on the STARS display (CTRD) as well? They reference 5-2-21 and 5-14-5, terminal and enroute altitude filters respectively. ASDE doesn't have controller-settable altitude filters.
Assume that the radar site is not on-airport and the target has dropped off the ASDE display prior to appearing on the CTRD, so I can't compare the two Mode C readouts in real time. I would contend that that would fulfill the spirit of c3, but let's say I can't even do that.
