g. Landing Behind a Larger Aircraft—On a Parallel Runway Closer Than 2,500 Feet Apart. When landing behind a larger aircraft on a parallel runway closer than 2,500 feet apart (Figure 12), pilots need to consider the relationship between the runway threshold locations, the relative GS descent paths/locations and possible vortex drift onto your runway (see paragraph 12 for aircraft classification definitions). If you have visual contact with the larger aircraft landing on the parallel runway, whenever possible, stay at or above the larger aircraft’s final approach flightpath. Note its touchdown point. Be aware that the aircraft descending to the more distant threshold will generally be slightly higher depending on the amount of threshold stagger. See Figure 12, Avoidance Procedure Landing on Parallel Runways Closer than 2,500 Feet.
