steakvendor
Even from higher level facility to lower facility?Were you a CPC at you last fac? I resigned as a cpc, came in over a year later on the exp bid, If you do that you go to the bottom of the cpc band wherever you go, just a heads up.
I resigned as a cpc, came in over a year later on the exp bid, If you do that you go to the bottom of the cpc band wherever you go, and if you withdraw or wash, same applies at next fac
