southwest416
Hello everyone!
I've written a quick open-source python program to automatically generate ERR packages for up to 5 facilities at a time. This program automatically generates a cover letter, 3330-42, and 3330-43-1 for each facility, and eliminates the process of searching for a facility's regional office info, location, pay band, etc, for each individual facility you apply to. Now, all you have to do is select the facility ID and all the information automatically populates in the generated package. Detailed instructions for use can be found on the GitHub page or in the INSTRUCTIONS.txt file found in the downloaded folder. The most up to date version can be found on the GitHub Releases site or in the PointSixtyFive Resources page.
This software also will prompt you to attach a resume, performance plan, and a signed 3330-43-1 that will be appended to each generated package, making it a one stop shop for your ERR paperwork!
If you choose not to attach your resume, performance plan, or signed 3330-43-1, you must still attach them once you print the generated documents. Attach the resume and performance plan; sign the cover letter, 3330-42, and 3330-43-1; and have a supervisor sign 3330-43-1 under "Signature of Rating Official," then fax or email to the appropriate region as indicated on the cover letter. Please find the appropriate region contact info on the FAA KSN website, as this info changes frequently and seemingly without notice.
Facility information is pulled from publicly available sources including FAA OPSNET, 123ATC, PointSixtyFive, r/ATC, etc. I then personally augment this information as necessary to correct for inconsistencies among these sources before it is published in the Excel database. At this time, the database is not synced with any server, so please check back here often to get the most up-to-date version before generating paperwork. Eventually, the goal is to either port this to a web app format, or to get the program to a point where its databases update from a web server automatically before generating packages, to reduce the number of updates and ensure information is as up-to-date as possible.
If you have any questions, comments, or suggestions, please feel welcome to leave a response in this thread, on the PointSixtyFive Resource page, or open an issue on GitHub! Also, if you are interested in contributing to this project, you are more than welcome to do so, and feel free to reach out if you're interested in collaborating!
