If you only fill out the excel file, then run the program without attaching any files, does it work properly? Alternatively, if you leave the excel file blank, and attach all the documents you like, does the program otherwise work?
Another thing that would help is running the program from command prompt. If you open the search bar at the bottom, type “cmd” and launch command prompt. If the program is in your downloads folder, cd to the directory. (eg. “cd Downloads\ERR-Generator-v2022.07.13”). Then type “ERRPDFfill.exe” to run the program. Attach the files as you normally would, then click run. The program should still crash but now it’ll print out some sort of error in the command prompt. If you could post that error, it would help me to identify the problem.
I tried both suggestions with no success.
I managed to copy the printouts just before the program closed completely. Here are the results. I'll try the command prompt method next.
I assume I have to save the Excel file after filling it, but if that's the case, I'm not sure how to change it from read-only to enable editing and save it with a name/directory that will be recognized by the program.
Instance 1: filled Excel file, no files attached
Traceback (most recent call last):
File "ERRPDFfill.py", line 549, in run
File "ERRPDFfill.py", line 473, in generate_err
File "pandas\io\excel\_base.py", line 1419, in __init__
File "pandas\io\excel\_openpyxl.py", line 525, in __init__
File "pandas\io\excel\_base.py", line 508, in __init__
File "pandas\io\common.py", line 795, in get_handle
FileNotFoundError: [Errno 2] No such file or directory: '1. Personal Information.xlsx'
Instance 2: blank Excel file, other files attached
