- Facility
- N90 New York Tracon
Per NATCA, 2 prior experience bids are coming out Mar 19-26. One for general FAA and one for N90.
Anyone know if you can request a specific N90 area if you apply direct there? Doubt they'd accommodate that but for the right area I would consider it.
For the uneducated, what is the difference between general FAA and N90. What is N90?
Use the usajobs resume builder and make sure you put everything required in the bid and you should be good to go.
Good to know, thank you.
Any tips or tricks for applying to this opening for a couple of Navy controllers getting out soon?
It was a huge success.What were the results of the last prior experience N90 bid? Wasn’t there 100 applicants and 75% referred 50% got TOLs and then 10% actually went thru with it? (These are just guesstimations) Makes you wonder what they’re game plan is...
How soon is soon? They've been turning down people who have more than 120 days left. Either way, expect a long wait between applying and starting.
You’ll get it be patient. Once you hit that 120 window you gotta start bugging HR for the next steps.I am 6 months out, hoping the 120 days is overlooked considering the increasingly long wait times.
Entrance on Duty Requirements (EOD): If you are unable to complete all pre-employment requirements within 15 months of receiving a tentative offer, the FAA may rescind your offer for this vacancy. If you are a current military member in active duty service, you must submit a copy of your DD Form-214, or written documentation (certification) from your branch of service certifying that you are expected to be discharged or released from active duty under honorable conditions no later than 120 days after the date the certification is signed.
This is what I received.An allsources bid does not have the 120 requirement, the previous experience bid does. It has nothing to do with claiming veterans preference.
