There's talk in the 2nd qtr NCEPT thread about it. Check it out for full detailsHeard a rumor last night that they will be allowing facilities to drop just below the national average in order to allow more people to be released. Anyone heard anything substatiating this?
Which means if you're at the national average, and show -4 you'll only be able to release 1
Just going off the "slightly" part. Let's say your number is 22. National average is 82.xx which means you need 19/22 to be at or above the national average. Do you think they are going to allow to release 4 and be at 15/22 and 68% staffing? Speculation, but a more likely outcome is release one, making the numbers 18/22 or 81.8%. Which is "slightly" below the national averageThat's not true. If you're just above the national average and your Y number is -4, you can have up to 4 people selected on the panel. You need to keep in mind that if 4 people were picked up and you were just above the national average, all 4 would have category 2 release dates and could be stuck at said facility for up to a year. A lot can happen in a year, including trainees checking out which mitigates the future loss of anybody selected by the NCEPT. That's the idea behind this new change. And if your facility's Y number is -4, chances are your staffing is already pretty good and/or you have a lot of trainees expected to check out.
The number of releases would be restricted so that a facility would drop only slightly below the national averages
All that amounts to is one large hit of people being released instead of a more gradual flow of people out the door. 4 releases in one go which drops you out of both actual and projected range, and leaves the facility at the whim of hiringYes, that is exactly what they are allowing. Using your example staffing, even if 4 people got picked up it's not like they would be released overnight and drop the staffing down to 15/22. They would be year long release dates and the FAA, using their formulas, believe there are enough trainees at that facility to replace the projected losses before the staffing level becomes worse than what it currently is.
The "slightly below the national average" line you're talking about refers to rounding the Y number up to the nearest integer. If your Y number (additonal inbounds needed to meet the national average) is -3.7 that means you're projected to be 3.7 people above the national average. So if you release 4 bodies, you'll eventually be 0.3 people below the national average. In other words, slightly below the national average. It's all about projections.
I see your point, but if your staffing is already good and you have 4 trainees expected to certify in the next year with no projected retirements, what's wrong with releasing 4 people a year from now? Now if less people certify than projected, yea your staffing will take a hit. But movement in future NCEPT panels will be frozen until you get more people on board. That's the protection.
As a controller with bids out, it's tough to argue against this change. The old way was much more reactive (someone has checked out, now one person can be selected) while this is a much more proactive approach (3 people will check out, 3 people can now be selected). It remains to be seen how it all pans out, but it certainly seems like this will get more people moving and in a quicker manner than before. Win-win.
So a -3.5 in column y would be 3 releases? Or 4 releases?
I'm starting to get my hopes up.Based on previous information I believe 4 because it is rounded up. Someone said beforehand that a 0.3 would be a 1. Not 100% though, just my understanding
I have bids out as well, I'm just saying that now you just better hope you're one of the several that can be released, otherwise who knows how long it will take for them to pipeline new hires in. That's the key to the whole process.
This is a positive step, but still leaves questions and problems to be addressed
-3.5 would be 4. -0.3 would be 1. -0.1 would be 1 as well. They round up to the nearest whole number.
He's right.That's correct, but speaking math-wise they're actually taking the absolute value and then rounding up to the nearest whole number.
Rounding -3.5 up to the nearest whole number would be 0, since there's no negative whole numbers. And just rounding -3.5 up to the nearest integer would be -3.
Aboveso must you be at or above the national average then have the ability to dip below, or is this basically saying you can be well below as long as you have a bunch projected to be above?
