You just have to wait 2 years to get your 6 months release date. Taps head.The whole goal of NCEPT was to achieve better release dates, in that it succeeded greatly.
Still better than the bid system with 5+ year release dates and a rigged system. NCEPT (while shitty) was a massive improvement upon the old system. Hopefully they take its successful aspects into consideration if they change it.You just have to wait 2 years to get your 6 months release date. Taps head.
I like a lot of NCEPT. The quarterly meetings. Staffing numbers, gains and losses etc. I think there needs to be a new way of counting staffing and taking into account local issues that seem to plague a lot of these places that look good on paper while working six day work weeks.Still better than the bid system with 5+ year release dates and a rigged system. NCEPT (while shitty) was a massive improvement upon the old system. Hopefully they take its successful aspects into consideration if they change it.
Getting people where they want to go from the academy is the first step to fixing it.Still better than the bid system with 5+ year release dates and a rigged system. NCEPT (while shitty) was a massive improvement upon the old system. Hopefully they take its successful aspects into consideration if they change it.
Definitely, the NCEPT took a lot of the old-boy system away when they introduced the numbers system to determine most movement. Including what you've said, they should be more transparent with the process too.I like a lot of NCEPT. The quarterly meetings. Staffing numbers, gains and losses etc. I think there needs to be a new way of counting staffing and taking into account local issues that seem to plague a lot of these places that look good on paper while working six day work weeks.
I think they need to hold people to their selections. You put in, you get it, that’s now your job. Outside of hardship criteria you are moving. No more taking the only slot out just to turn down the offer in the end.
Have people work a year certified before bidding to give the people who have been there longer a shot. Instead of training people to take your spot out because they know someone or bid a high priority spot.
Two separate NCEPT numbers run. Facilities are ran with the first list of any applicant within 3 levels. 8-11 etc. Then re run the list with everyone that applied. Regardless of level. Force facilities to select first from more qualified candidates and promote upward movement. This should help open spots at the mid level facilities where people seem to get stuck.
This couldn't be more true.Getting people where they want to go from the academy is the first step to fixing it.
The FAA should just do local bids for facilities like they did with N90. Get people that want to be at the facility they apply for.Getting people where they want to go from the academy is the first step to fixing it.
Like maybe you can’t get ZFW or DFW out of the academy. But how bout the 20 GA airports in the area. Get more people where they want to live and less people transferring.The FAA should just do local bids for facilities like they did with N90. Get people that want to be at the facility they apply for.
There is a bit of a legal issue associated with that, they could possibly do it in conjunction with national bids, but the hoops they'd jump through makes it seem really unlikely.The FAA should just do local bids for facilities like they did with N90. Get people that want to be at the facility they apply for.
What you mean. Go on USA jobs. Every agency is hiring locallyThere is a bit of a legal issue associated with that, they could possibly do it in conjunction with national bids, but the hoops they'd jump through makes it seem really unlikely.
They did a NYC resident bid for N90. Why couldn't they do it elsewhere?There is a bit of a legal issue associated with that, they could possibly do it in conjunction with national bids, but the hoops they'd jump through makes it seem really unlikely.
The FAA is an excepted service and not subject to OPM hiring practices under Title 5 CFR. Hence where Public Law 114-190 comes into effect and dictates our hiring practices.What you mean. Go on USA jobs. Every agency is hiring locally
Odd. At least maybe a few select bids like ZOA could be helpful. If they can use the n90 rulesThe FAA is an excepted service and not subject to OPM hiring practices under Title 5 CFR. Hence where Public Law 114-190 comes into effect and dictates our hiring practices.
Local hiring is near impossible to meet 114-190 requirements, hence the national hiring.
N90 is an extremely special case which has an exception.
Better academy placement is the best solution that is both legally attainable and realistic.
you seem to be forgetting 9-11s are the best staffed facilities in the agency. this only works if all facilities have an equal opportunity to gain, which they don't.Two separate NCEPT numbers run. Facilities are ran with the first list of any applicant within 3 levels. 8-11 etc. Then re run the list with everyone that applied. Regardless of level. Force facilities to select first from more qualified candidates and promote upward movement. This should help open spots at the mid level facilities where people seem to get stuck.
that only works when you're in a desirable area of the country. it screws less desirable areas.Like maybe you can’t get ZFW or DFW out of the academy. But how bout the 20 GA airports in the area. Get more people where they want to live and less people transferring.
i got to go to a “less desirable center”. But it’s where I already lived. So I’m staying here for life. I’ll be staffing for others to leave. We have so many that were forced here and just leave when they can. I also know of people from here that couldn’t come. It’s like what are we doing
supply and demand.They did a NYC resident bid for N90. Why couldn't they do it elsewhere?
It would be extremely helpful if they could or cared to make the case, though it'd have to match similar to N90 numbersOdd. At least maybe a few select bids like ZOA could be helpful. If they can use the n90 rules
Not true. I live in a non desirable place and ppl haven’t been able to come back. You’d still have the national placement for everyone else. The more people you can take out of the transfer game the easier it will be.you seem to be forgetting 9-11s are the best staffed facilities in the agency. this only works if all facilities have an equal opportunity to gain, which they don't.
supply and demand.
Aside from centers I think the majority of releases during NCEPT have been 7 and below. And every high level release is another spot for a lower level to move into. I have seen plenty of 9-12 that are unable to release and unable to gain at the same time.you seem to be forgetting 9-11s are the best staffed facilities in the agency. this only works if all facilities have an equal opportunity to gain, which they don't.
supply and demand.
How do you staff the places no one wants to go to then? Because as the ncept has shown most want high dollar facilities and hardly anyone apply for mwh and the like.Getting people where they want to go from the academy is the first step to fixing it.
Put an incentive for people to go to those places like they did with GuamHow do you staff the places no one wants to go to then? Because as the ncept has shown most want high dollar facilities and hardly anyone apply for mwh and the like.
