DowntownTG
I had some signed by FLM and some signed by ATM. All of my bids were accepted by HR.
Northwest mountain seems messed up in the autofill for the cover letter. can someone verify the address and information.MJ updated ERR Package with a new update entry:
Updated HR phone/fax numbers
Read the rest of this update entry...
Heads up to anybody, Houston Austin and Louisiana now belongs to southern region...
Memphis and Indiana now belong to southwest...
Its Its wierd I know, don't ask me why.
Address:
2200 S. 216th St.
Des Moines, WA 98198
All other info should be unchanged from the HR POC chart on this thread.
How on earth do you enter the correct information on the 3330-43-1 document? Adobe won't let me enter my "Series and ATC and Career Level Codes" because it only accepts numbers and not letters. Also, I can't enter "N/A" in the fields that are not applicable as stated in the instructions because it will only accept numbers as answers. Do I seriously have to print this off and write the information in by hand? Thanks.
Edit: Also, can't even enter my Score because the document automatically changes the number back to '0' even after I enter the correct number. Unless someone tells me otherwise I'm going to assume this PDF file was created just for show or something.
I don't have that as an option anywhere. Am I supposed to use a special version of Adobe or something?Use Adobe insert text, that's at least what I do and just place it over where you need to.
Edit: Apparently you have to buy Adobe in order to fill this stuff out. I'm using an alternate program as a work around. Thanks.
No one.Who fills out the "Selective Placement Factor" part of the 3330-43-1 when applying for positions on usajobs?
Whatever you want to submit.For the resume part, do they want a full professional resume, or do they just care about the air traffic part? I got into ATC at the cutoff age, so not sure if I should include prior career experience or just leave it as just relevant agency stuff. Thanks
Full package for each. if there’s a lot I’d probably call that HR and ask to send one copy of the things that dont change And they’ll let you know whats ok with them.Here's a dumb question that may have already been answered. The sample packet is 13 pages long including everything. Hypothetically speaking, if I submitted 10 ERRs to the same region, do i have to do a new packet for each facility i put in for? So I'd have to submit 130 pages total?
instead of using the form fill field, after completing the rest of pdf, type it over the box using fill and sign tool in acrobat or use some other program to write it. or print it out, write it in, scan itOn the PDF version of the FAA Form 3330-43-1, the Announcement Number will is too long, and won't fit in the correct box. This is for a job that is not an ERR. Even the from the FAA.gov site, the PDF won't let me put in the entire announcement number. Any ideas?
The announcement number for reference is ASW-ATO-20-MS282-67537
Thanks.
