7,739 replies · 1,227,960 views · Page 305 of 387
  1. zedex #6081
    brsana said:
    it's a long strenuous process, you have to want it its no walk in the park
    It can be. But it can also be the easiest job ever to get into for some people. I took three or four days off of work for the various tests, the rest of the time was living my normal life prior to the bid and waiting. There was no interview, no college degree required for some, just a lot of patience.
    Golf Sierra Bravo said:
    but does anyone know if it’s graded on a curve
    I can’t be 100% sure, but I thought I’ve read somewhere that it is graded on a curve to a point. I believe you have to pass the minimums and then it’s curved from there. Something like the top X% get BQ, next Y% get WQ. Qualified individuals are the remaining candidates who passed but didn’t make the curve cut-off. Not qualified means you straight up failed.
  2. 32andBelow #6082
    I know no one really knows how the ATSA is graded, but does anyone know if it’s graded on a curve — relative to how others perform — or on a traditional/numerical scale (e.g., 90-100 is an ‘A’, 80-89 is a ‘B,’ etc.)?
    Just curious as I’m hyped for the upcoming OTS bid.
    No one knows how they grade it and they may change how they grade it every time
  3. SkyPapi #6083
    I've seen folks on here report using ATSA results from previous bids and seeing their reported scores change. Aviator, the FAA's online application tracker, even uses the verbiage "...based on most recent ATSA results" when describing each of the qualifying rankings, so it is almost certainly relative to how others score.
  4. Even Steven #6084
    I hope so.
    But what I don't quite understand is, assuming they grade the test relative to how others score during a specific bid, why they would curve ATSA scores from previous bids? In other words, if they're updating scores from previous bids, then it seems they're curving the test relative to how others have scored in the past few years instead of a specific year like 2020 ATSA scores, if that makes sense.
    Anyway, I guess there's really no point in trying to figure it out; I was just curious.
    I just have to do the best I can.
  5. SkyPapi #6085
    I hope so.
    This is merely speculation at this point, but I'd imagine that rescoring has precisely nothing to do with the previous bid and everything to do with the current one. All the FAA would have to do is take the actual numerical score from a previous bid and compare it to the ones in the current bid. Thus someone's WQ from 2019 could be a BQ in 2020, suggesting a less competitive applicant pool.
  6. Even Steven #6086
    Gotcha. And what if someone decides to retake the test, would the new score void the old score?
  7. SkyPapi #6087
    Yes.
  8. Alfa Mike #6088
    hey cncer, I sent you a PM a while ago. Tagging you here in case you didn't see it...
  9. yegorspencer #6089
    dakloss1990 said:
    Yes.
    What if your new score is worse than the previous year? Wouldn't they take a better score out of the 2?
  10. SkyPapi #6090
    No. They use your more recent score regardless of which is better.
  11. yegorspencer #6091
    Would you recommend taking another ATSA test? I got qualified for 2020 bid.
  12. GulfBravoPapa #6092
    If you only scored qualified, absolutely.
  13. Slumpy1990 #6093
    I got qualified this bid and got a TOL but that's probably a very rare exception
  14. Alfa Mike #6094
    MedExpress question: it asks for a list of all current/past Rx. I've been going to the derm regularly for the last 6 years for various eczemas and skin issues. I've probably been prescribed like 20 different medications over trial & error. I genuinely can't remember all their scientific names, I only remember what I'm currently taking. So how should I go about filling out the form?
  15. RB #6095
    Answer to the best of your knowledge (and truthfully).
  16. Typeass #6096
    Ask the pharmacy for the list.
  17. AllSeeingFry #6097
    Man, I'm starting to get worried about my clearances. Maybe I'm just being personally negative but god I hope I make it in.
  18. Nickkos94 #6098
    First time going through all of this process (and first post here...)
    Is anyone having a difficult time scheduling their MMPI-2? I haven't heard back from the proctor in a full week. My CIL said there could be delays at some facilities for COVID-19 reasons which is understandable. Should I call a facility that's further away or just wait it out? I'm trying to be as painless for the HR and FAA staff as humanly possible lol. TIA!
  19. Preformer_93 #6099
    Make every attempt to track down prescription lists. Go get pharmacy records. Go get records from your doctor. Try to put down as much info as possible.
  20. Oranienburger StraBe #6100
    Does anyone know the true length of online basics? My iPad email states that I am enrolled in basics from 8/9 - 9/2. I thought basics was a 200 hr five week course. :boo:
