NEST NEST
Alpha_bravo2
PNS Pensacola Tower
Gotcha I figured if that were still the case more people would be scamming the system.
Nfingers
what if you are not within the probationary period?
They can still terminate you. The nest Sop and it's process is on the ERR page. It depends what the recommendation the panel gives you, and if the faa has any facilities available in that range. If not. You fired. Lol
Pretty much, but it's very much the lottery. They could also terminate you.
wow. seems like a scary deal. makes it seem like firing is easy even if you are not on probation.
RavenYZF-R6
In a couple days I'll write a full writeup on what has gone on with mine. It's wild.
If you have been a CPC somewhere prior they cannot terminate you after your first withdrawal or washout correct? On a second washout or withdrawal they have the option to terminate instead of retain. Then after you obtain certification somewhere it resets the clock so to speak. That’s my understanding anyway, if it’s not your first facility.
Nfingers
From my understanding. Partially correct. So if you go to the nest after washing at a level 8 people something. Let's say the nest decides the facility that will be good for you are 4s and 5s. They run the PPT. If all the 4s and 5s are staffed well enough then they cant offer a atc facility. Then they'd offer FSS or termination.
MaintainVis
I take it you didn’t have any scopes?
