Terminal Class pass rate
3,224 replies · 819,227 views · Page 124 of 162
  1. sczarn #2461
    stonemalone99 said:
    DLH seems to pop up quite a bit on experienced bid lists. STP was just on one of the last few experienced lists. I've seen FCM pop up for academy lists more than anything other tower in MN. Obviously no one's getting MSP out the gate. MIC (Crystal) would probably be the easiest and shortest training time for a slow level 4.
    Thank you!
  2. GulfBravoPapa #2462
    Depends where you go.
  3. 32andBelow #2463
    Alfa Mike said:
    I was in this class. I resigned the day before eval. I just hated ATC and didn’t want this for myself. I also didn’t want to be a contributing factor for someone losing points on the PE and not getting the job.
    I believe 1 didn’t pass because of some RPO error which caused him to get a deal. Very unfortunate
    It’s better to pass and jump on a mandatory that no one wants then quit. But I hear you not wanting to hinder someone. That’s crazy that can even happen
  4. Motodog #2464
    sczarn said:
    What is the salary after you leave the academy and start out at the new location?
    Go to 123atc.com and click on ‘list of facilities’. It’ll show salaries, facility level, etc
  5. MJ #2465
    Or use one of like 6 different ways to find it here
  6. Phanatical #2466
    Lol right? At least the info on here is more-or-less current.
  7. GulfCharlie #2467
    Going to need that 40% SSR table. Btw, your TPS reports had an error.
  8. Motodog #2468
    What are the 6 different ways?
  9. chroma #2469
    One way is to click on Wiki, then Facilities, then click on your desired facility and it will tell you everything you need to know about the location.
  10. Motodog #2470
    Thanks man, saw that. Mostly I was goofing on ADMIN for their, or on here for ‘like’ 6 different ways..lol
  11. Kazander #2471
    Lotta people asking basic questions they could have easily looked up.
  12. Auburn5 #2472
    Does anybody know when the next terminal class graduates?
  13. Alfa Mike #2473
    End of September
    Believe it or not, all those 4 FAI slots went to people who actually wanted to go to Alaska. Only 2 were mandatory. So I didn’t think it was necessary to take the FAI slot for/from anyone — so at that point I was just making sure no one might have lost points because of me
  14. Fate #2474
    What do you mean by “lost points”?
  15. julietoscar #2475
    From what I've heard, two people work the same problem together on local and ground, so if one of you is weak, you can bring the other one down
  16. Fate #2476
    Ahhh ok thanks for the clarification
  17. Kazander #2477
    They can't directly lose you points, but if they're doing a shit job it can mess up your flow.
  18. Fate #2478
    So even if it’s not your turn there’s still pressure knowing you can mess someone else up. I guess that kind of stresses the importance of study sessions and making sure all of your classmates are up to par.
  19. Phanatical #2479
    The evaluations are set up where one student works local while one works ground. One can’t directly influence the other, but if ground bumbles through an apreq that local ends up inadvertently approving (example), then local gets the points taken away as well.
  20. Alfa Mike #2480
    Another example is if local hands off the wrong butter bar to ground & ground doesn’t notice
