7,739 replies · 1,227,960 views · Page 41 of 387
  1. Dingalings69 #801
    Lol tbh after reading the wording it does seem like p1 bq p2 bq p1 wq etc
  2. Hannahyates #802
    amo4 said:
    not necessarily. Not a lot of people got the chance to test. A LOT of people’s tests were cancelled (mine included, but I rescheduled and drove 6 hours to take it somewhere else) so it’s a very small applicant pool. Also, not everyone got referred (a handful of plain Qualified’s have said they were not referred that took the test during this window). AND who knows how many BQ’s there are! There might not be many and they’ll have to dip into the WQ band. We just don’t know! It’ll be interesting to see.
    I’m OTS and p2-qualified-referred as of yesterday
  3. AnyTrafficPleaseAdvise #803
    SIXTY-NINE said:
    I know there's a debate about CTI schools helping or not but do they ever advertise that you'll do better in academy with statistics?
    Seems like an easy way to bring applicants in.
    When I went through in 2017, CAMI was looking at OTS vs CTI and accumulating data for the success rates of each group. Anecdotally, a CTI degree doesn’t mean a damn thing. I had a classmate with an Embry-Riddle ATC Degree fail, and We had people with no aviation background pass the class. If I remember correctly 3/7 CTI grads passed, and 8/11 OTS. Obviously a small sample size, but I don’t think it gives people a real leg up.
  4. kshaky #804
    I think the biggest selling point, especially as hiring decreases as planned, is that your chances are better of being selected if you are Pool 1 (assuming you score well on the ATSA).
    I would say CTI gives you the advantage of experience with the material and if taken advantage of makes one's chances of passing the Academy a lot higher. The problem is the experience means nothing if you get nervous and throw your evals or don't work hard to be as proficient as you need to be.
  5. 32andBelow #805
    Back when CTI school were at their peak some had labs that were nicer than the academy. Others barely taught you anything. There was a proposed hiring plan where the faa was going to hire people from the good CTI schools with priority. But that was shelved for the BQ which I failed 3 times. 🙂
  6. dk001 #806
    your status JUST changed yesterday? or did you check for the first time yesterday
  7. SIXTY-NINE #807
    Yeah I get the draw of being in Pool 1 but going to school for 2 years and dropping 10K+ seems like a waste of time/money when you can just go to a regular college and try to get in as a Pool 2 on the side... this topic has been beaten to death but I'd just actively dissuade people from getting a CTI degree then.
    I remember that an instructor for a CTI posted on this forum a super long time ago and said that it depends on which school you go to though, one in particular had a 90%+ pass rate for academy if you got past the ATSA
    Your life is a Shakespearean level tragedy the more I learn about it
  8. Alvarolaham #808
    Hey! Third time applying... I got Pool 1 = Best Qualified. I am prior military (USAF TACP). Best of lucks to everyone!
  9. Hannahyates #809
    It just changed I believe it was Thursday or Friday on usajobs because i check it daily lol!
  10. sldsills #810
    I hope this isn't a stupid question. Is the whole hiring selection based off of the ATSA alone? Do they not look at your prior education or experience even after being referred over?
  11. 32andBelow #811
    Correct. All your resume does is prove you meet the qualification
  12. Light chop #812
    Does anyone have an idea of how many people applied or how many were referred?
  13. Dingalings69 #813
    About tree fiddy
  14. SkyPapi #814
    Good afternoon all,
    I figured I would ask again since I have gotten very little information after nearly two hours on the phone with PSI/FAA.
    My status changed to "Not Referred" on USAJobs right around when everyone started hearing back about their exam. Perhaps my reading comprehension leaves something to be desired, but the message below my referred status (see attached) seems to imply that I never took my ATSA (which I definitely did, and PSI confirmed as much). I have seen "Not Referred" messages from past bids state more bluntly that "A list of applicants has been sent to the office with this announcement. Your application was not included at this time." For that reason, I am holding on to hope that this is just some kerfuffle, and wanted to see if anyone else on here was having a similar experience.
  15. TushingPin #815
    dakloss1990 said:
    Good afternoon all,
    My status changed to "Not Referred" on USAJobs right around when everyone started hearing back about their exam. Perhaps my reading comprehension leaves something to be desired, but the message below my referred status (see attached) seems to imply that I never took my ATSA (which I definitely did, and PSI confirmed as much). I have seen "Not Referred" messages from past bids state more bluntly that "A list of applicants has been sent to the office with this announcement. Your application was not included at this time." For that reason, I am holding on to hope that this is just some kerfuffle, and wanted to see if anyone else on here was having a similar experience.Not referred.png
    I haven't heard of this, but if you've been on the phone with FAA HR a few times, what answers are they giving you? Obviously you know that you took the exam, and can semi prove that via PSI. If they're telling you "You haven't taken it" then I would ask to speak to the supervisor (or whomever is above that person and simply explain the situation to that point. I have found that sometimes HR can be stubborn, and refusing to help because of a blanket statement. Good luck!
  16. MJ OP #816
    dakloss1990 said:
    Good afternoon all,
    You need to call aviation careers. Don't let them not give an answer. Ask to speak to higher ups if needed.
  17. Hannahyates #817
    Just waiting and wishing TOL’s where coming out as fast as the atsa exam status did!
  18. zulululu #818
    what’d ya score?
  19. Hannahyates #819
    amo4 said:
    what’d ya score?
    P2 qualified referred, I probably won’t get one but whatever lol!
  20. GodHelpMe #820
    T
    This bid might be different. Don’t let your hopes down! Got referred for a reason.
