CorrectThere’s no advantage to certifying before the January raise as a developmental, correct? You would go the bottom of the band regardless.
Wait I thought if you certified before January you would go to CPC min. Then get the 5.2% then get more. On the other hand if you certify after January you would just go to the CPC min and basically get nothing? Am I wrong? Does this raise raise the CPC min? Am I missing something?Correct
The January raise moves the bottom of the CPC band up so it's the same thing as getting certified before or after. The only thing that moves you through the bands are the 1.6% June raises.Wait I thought if you certified before January you would go to CPC min. Then get the 5.2% then get more. On the other hand if you certify after January you would just go to the CPC min and basically get nothing? Am I wrong? Does this raise raise the CPC min? Am I missing something?
Umm ima do some bad mathWait I thought if you certified before January you would go to CPC min. Then get the 5.2% then get more. On the other hand if you certify after January you would just go to the CPC min and basically get nothing? Am I wrong? Does this raise raise the CPC min? Am I missing something?
All your June raises are basically null and void and you lose all of the raises you received during training.Right and it's complete bullshit.
$9-$12 an hour is certainly what it feels like with all our deductionsUmm ima do some bad math
You make 8 dollars a year as a developmental
The bottom of the cpc band is 10 dollars
You certify before January, you get 10 dollars because it's processed instantly in 2023.
In 2024 you get another cpc raise to 12 dollars and make 12 dollars
Post january
You make 8 dollars and cpcs make 10. The raises go in and you make 9 dollars and cpcs make 12.
You certify and make 12 dollars.
January doesn't matter as a target for certification
UNTIL June.
If this was a little bit later
You make 9 dollars and cpcs make 12, on Jun 1 you get a riaee to 9.01 and cpcs make 12.05. You certify Jun 2 and make 12 dollars.
On the other hand if you certify before Jun you make 12, and then 12.05 Jun 1
BUT the trainees impacted by covid (2-3 1.6% compounding raises) got to telecommute while other federal employees didn't even get paid!
Except those of us that had to come in and work sector on 5/2 but not train.Umm ima do some bad math
Post january
UNTIL June.
Gotta stay socially distanced sorry I'm not comfortable training. Wanna get beers after work?Except those of us that had to come in and work sector on 5/2 but not train.
I remember specifically reading the 1.6 raises while in training do count. 99% Sure givenAll your June raises are basically null and void and you lose all of the raises you received during training.
To clarify they may be kept if you are a cpc it,I remember specifically reading the 1.6 raises while in training do count. 99% Sure given
I certified last year as a CPC IT, and I was 4k above the bottom of the band at the beginning of this year.
My 1.6 were just based off of my CPC IT pay rate.
Only thing you lose realistically is the difference of 1.6 percent pay raise from your CPC IT pay rate and the bottom of the band
At least you got hazard pay,Except those of us that had to come in and work sector on 5/2 but not train.
Oh wow. This. Is. HUGE!![]()
