SFGiants10
Is there a difference in the NEST list that you get if you wash out vs withdraw from training?
Prior CPC or is this your first facility?Is there a difference in the NEST list that you get if you wash out vs withdraw from training?
Prior CPCPrior CPC or is this your first facility?
Prior CPC or 1st facility? Read the NEST Placement link I posted above.So if you are at a center and have all of your d sides, what happens if you withdraw from training for radar?
If they retain you (they could terminate your employment and I've seen it done with people as high as D2 at 12 centers), you would be given a list of no more then 5 facilities currently below the projected national average. Everyone who is a training failure will be placed before you.1st facility, not really sure what the "rules" are, like if you have to be unsuccessful or if it's a choice, I would gladly take a downgrade in pay to go from a level 12 center to a smaller tower.
Even if your mind is fairly made up, I'd encourage you to continue to work hard and keep training. If your training is suspended, they'll interview your FLM and each member of your training team in a TRB (Training Review Board). If they all like you, when the question comes up of, "Do you think this person can make it at a smaller level facility?" the odds of them giving you a positive review go up tremendously.Yeah the termination part would be what I'm afraid of...
If you are unsuccessful in training at an En Route facility and get NEST'ed, I read that you must return to the academy if offered a Tower. If you fail the Terminal academy class, are you then completely terminated?
My terminal class had an Enroute washout that failed his second local PV and was let go completely.
Generally. I know of a person recently that went through the Academy again. First time was before 2014 for tower, didn't make it at the facility, was terminated, reapplied to one of the all-source announcements, was hired, sent to basics and initial tower at Academy, and was told that it was still job-jeopardy. Passed so it didn't matter I guess.You can only face job jeopardy at the academy once.
As far as returning to the academy you're correct. The language is in the 3120.4P, Chapter 4, Section 2, Paragraph D.If you are unsuccessful in training at an En Route facility and get NEST'ed, I read that you must return to the academy if offered a Tower. If you fail the Terminal academy class, are you then completely terminated?
That's unique though. The first career was terminated, everything reset. In any case, that's not applicable anymore. Once you're fired you can't be hired back.Generally. I know of a person recently that went through the Academy again. First time was before 2014 for tower, didn't make it at the facility, was terminated, reapplied to one of the all-source announcements, was hired, sent to basics and initial tower at Academy, and was told that it was still job-jeopardy. Passed so it didn't matter I guess.
