The fix is not simple.
Upward mobility. Guaranteed career plan that gets you making from level 5 pay to level 12 (if desired) in 8 years or less. Hard to staff towers? GUARANTEE an escape to desired location and a timeline. This also let's you know when you'll need people instead of I just out in for a sup bid. (STRUCTURE LIKE GUAM BID, BUT FOR BAD FACILITIES HERE)
Get the bad facilities I'm shape (n90 seems to be improving greatly) but there are others. Nobody should have to wait YEARS to START training (pandemics aside) Make raises timed base-these delays (including pandemic) make it impossible to get a performance based raise. This kills tsp lifetime growth, delays your high three etc. Complete and utter disgust at this performance based system....that uh you can't perform for until we say it's OK? There needs to be a back up (like zny put position) at all facilities.
I'm excited for direct hiring with cti..BUT once again there is no standard. Make basics and map available for everyone free online. I'll narrate the powerpoints. If someone says they know it, make that part of the application.
Retention-Why aren't there more people in high up positions with qualified experience.
Things you can't do-go from a level 5 vfr tower to a level 12 tracon.
Things you can do- (if you know people)
Go from level 5 vfr tower to management at level 12 tracon
Go from level 5 vfr tower to traffic management at level 12 tracon
People want money and have no other way to get there. This is a huge shortcut around experience and ncept requirements.
Partially union aimed but hold people accountable-every detail should be required to maintain currency. People that haven't worked traffic in over 365 days are now a support role and should be taken off the numbers.
The hardest, staffed facilities get the lowest scorers and last picks for a reason. Some sort of living stipend or something might get people above 70.00% in okc to the right facilities.
For example- you live in Florida and went to embry riddle. You have a natural skill for atc and get 98% at the academy. Your family and support system is next door to ZMA.
You get the top of the list and go to Texas because it's closest.
Who goes to ACK, FAI, LA, Oakland, NY? The bottom of the list and volunteers. These facilities and trainees are set up for failure.
