- Facility
- POC Brackett Tower
Thats my plan every quarterJust assume you wouldnt have gotten picked up and drink
Delayed until next weekDid they already make the selections?
Yeah like I’m confused, when do they re-rank ? do all facilities re-rank ? does the list come out Monday or Tuesday?Did they already make the selections?
Looks like the level 8 or higher stipulation is fucking me out of round 2. Go figure.In Round 1, all facilities may gain bodies until their projected % CPC is equal to or greater than the national average projected % CPC (Cell AA6 of the PPT) and it is currently 86.6%. I don't know if they recalculate that national average after every transfer, or if they use 86.6% as a static number for the entirety of Round 1. This number of bodies is Column AB. If you click on any cell in Column AB, you will see that the formula uses Column G ("CPC Target") multiplied by the value in Cell $AA$6.
The theoretical "target" of the process is 100% projected CPC to target. The number of bodies a facility would have to gain to put them at 100% projected is Column AC. If you click on any cell in Column AC, you can see that the formula uses Column G with no multiplier, that is, 100% of Column G. Under the temporary rules for the current panel, this number is not used. It is purely informational.
In Round 2, all facilities which are ATC Level 8 or higher may gain bodies until their projected % CPC is equal to or greater than 90%. It appears that they tried to calculate this number of bodies in Column AV. But if you click on any cell in Column AV, you can see that the formula uses Column G multiplied by 0.85 instead of 0.90. So they couldn't even do that correctly. Probably someone should email the NATCA NCEPT people and point them to this comment, to make sure they make sure the FAA fixes it.
List should be out Tuesday. The panel meets Monday. They’ll probably have the affected facilities adjust their selections if necessary, but it wasn’t a massive amount that would warrant a whole new manager ranking across the FAA.Yeah like I’m confused, when do they re-rank ? do all facilities re-rank ? does the list come out Monday or Tuesday?
There are like 30-40 facilities that changed how many they could lose or gain. That's kind of a lot imo. I'm glad they caught it but it's pretty fucked up. I'm starting to think HR didnt do their job for there to be so many facilities. I doubt there are that many lazy ATMs that didnt update their workbook in time... but I could be wrong.List should be out Tuesday. The panel meets Monday. They’ll probably have the affected facilities adjust their selections if necessary, but it wasn’t a massive amount that would warrant a whole new manager ranking across the FAA.
Excuse me sir, there will be no "making sense" or "efficiency" allowed in this agency.There are like 30-40 facilities that changed how many they could lose or gain. That's kind of a lot imo. I'm glad they caught it but it's pretty fucked up. I'm starting to think HR didnt do their job for there to be so many facilities. I doubt there are that many lazy ATMs that didnt update their workbook in time... but I could be wrong.
Also, why does each facility have to update their staffing and not just one centralized area per region or national? When you get credentialed shouldn't that mark that your numbers increased by 1? Doesnt that whole process go outside the building to a higher level or does all that just stay in house? I feel like they could maybe streamline the process a bit.
Training success rate.Ok but how does ZNY need 388 to National average but their CPC target is only 296 ? and N90 needs 203 to National average but they’re CPC target is 226 ?
They need to stop screwing around and start only taking people born and raised on Long Island because no one else wants to be in the shithole of suffolk county, NY except people with family ties. Either that or start paying $275k base.Ok but how does ZNY need 388 to National average but their CPC target is only 296 ? and N90 needs 203 to National average but they’re CPC target is 226 ?
