- Facility
- ZTL Atlanta Center
Yeah, and that's how it should be. The thing that needs to change is once you get CPC, you should be able to gtfo relatively fast, and the next guy takes your spot behind you instead of infront of you.
They've only been putting out the lists right before the panel. For the category status it's pretty easy to figure out, but you don't have to because I put it on the facility's staffing sheet
The available slots have been tricky in the past to estimate, but it should be easier now with the changes. I'll add it to my to do list and try to post that info as well.
I agree with your staffing thought process, was more just relating to what you were saying with a real world example. I appreciate all your updates on here. I haven't been at work so been checking here for updates since I don't have KSN acesss
