- Facility
- Command Center
I do believe the 5/5 priority tool is ran tomorrow at 8am. Not sure what time zone. Good luck all.
ETI do believe the 5/5 priority tool is ran tomorrow at 8am. Not sure what time zone. Good luck all.
They post it on the ksn site. Should be available now.When does that data usually become public?
Ok where should I look? I don’t really use ksnThey post it on the ksn site. Should be available now.
If you start at DOT site, go to the FAA site. Then organizations tab-air traffic organization (ATO). On the right side halfway down it says “operation tools”. On that page it says priority placement tool on the third columnOk where should I look? I don’t really use ksn
The numbers at the bottom of the page (the "unofficial" PPT) have been updated as of this morning, but the full downloadable spreadsheet is still the 4/28 run. Usually they only upload the full spreadsheet each month, but Move78 made it sound like they'll update it for this pre-NCEPT run as well. Last time it didn't update until the end of the day.They post it on the ksn site. Should be available now.
So the weekly run won’t be uploaded as the official? At the bottom of the official it says “month NCEPT” instead of “month year” I’m not saying for this one but for previous onesThe numbers at the bottom of the page (the "unofficial" PPT) have been updated as of this morning, but the full downloadable spreadsheet is still the 4/28 run. Usually they only upload the full spreadsheet each month, but Move78 made it sound like they'll update it for this pre-NCEPT run as well. Last time it didn't update until the end of the day.
I don’t see that at all. This is what my page looks like after I loginIf you start at DOT site, go to the FAA site. Then organizations tab-air traffic organization (ATO). On the right side halfway down it says “operation tools”. On that page it says priority placement tool on the third column
this guy NCEPTs
You have to be on work computerI don’t see that at all. This is what my page looks like after I login
From today's (May 5th) final NCEPT run, the following facilities are eligible to pick up at least one person:From today's (April 28th) run, the following facilities are eligible to pick up at least one person:
A80 A90 ANC ATL BOI BOS C90 CMH CVG D01 D10 DAB DEN EWR FLL I90 IAH ICT JFK L30 LAS M98 MEM MSY NCT OAK ORD ORF PHL PUB SAT SAV SCT SDF SFO SNA STL TEB ZAB ZDC ZFW ZID ZLA ZMA ZME ZOB ZSE ZTL
ZDC and we can’t release for two more years?From today's (May 5th) final NCEPT run, the following facilities are eligible to pick up at least one person:
A80 A90 ANC ATL BFL BOI BOS C90 CMH CVG D01 D10 DAB DEN EWR F11 FFZ FLL I90 IAH ICT JCF JFK L30 LAS M98 MEM MSY NCT OAK ORD ORF PHL PUB SAT SAV SCT SDF SFO SNA STL TEB ZDC ZFW ZID ZLA ZMA ZME ZOB ZSE ZTL
Newly eligible since 4/28: BFL F11 FFZ JCF
Dropped since 4/28: ZAB
ZDC? That Grass isn't too green. It's all about DEN and F11. Time to get out those kneepads!ZDC and we can’t release for two more years?
Idc ZDC is near home and makes money I’ll get out whatever I need for thereZDC? That Grass isn't too green. It's all about DEN and F11. Time to get out those kneepads!
Give it some time, they'll be needing people for a while, though not like ZNY/N90.Idc ZDC is near home and makes money I’ll get out whatever I need for there
Why do you say that? Sure Leesburg is expensive as balls but the surrounding areas aren’t too badGive it some time, they'll be needing people for a while, though not like ZNY/N90.
